Full Version: [MAC]Scanning for TV shows doesnt work
Hi
When I add new movies to my movies folder, its set up so they scan and add automaticall. Apart from the odd mistake it works fine.
Im trying to set this up for TV shows too but im having no luck. I run a scan with my TV folder as the source and TVdb as the scraper and it just doesnt do anything.
To find the TV shows I have to manually browse to the folder they are in and there is no info for them at all.
Any ideas what I could be over looking?
MAC Os 10.5.8, Latest stable release of XBMC is it Dharma? Confluence skin.
debug log: http://wiki.xbmc.org/index.php?title=Log_file
upload to pastebin then post a link in this thread.
Thanks, never done this before so hope its right.
http://pastebin.com/VuK9dGKc
Hmm, I was hoping for someone else's input after I suggested you post the debug log as i'm not knowledgeable (yet) about debug logs.
But here goes:
There is a lot of "ERROR: GetDirectory - Error getting /Volumes/Iomega HDD 1/"
Are you sure the drive is connected (and on) to your laptop?
Thanks for taking time.
Its wired in fine, Its finding films ok, sometimes it asks if I want to continue scanning as it cant find the remote server though.
Built on Mar 9 2011 (Git:e9e9099)
did you try to update to eden beta2? (though not sure if it even runs on that ancient osx you are using)
Ive changed the folder names as per this thread and it works.
http://forum.xbmc.org/showthread.php?tid=111564
Nothing wrong with old skool apple bro Big Grin
