Full Version: XBMC goes into windowed mode when I switch inputs
So I run XBMC on a 47" LED. If I have it launched and in full screen mode, it goes into a small window mode when I switch HDMI inputs and then come back. Its always in the upper right corner. It's take about 1/4 of the total screen. I cannot return it to full screen unless I exit it and relaunch. I can control the windows screen just fine. Just can't expand it. Any ideas?
Does the same here. 2 solutions, the easiest for me is to press the "Green" media button on my "hacked" MCE remote (http://inchoatethoughts.com/launching-xb...ter-remote). It does the trick to have XBMC full screen when I press the green button.
The other solution, is with a keyboard. Just press "alt-Enter".
Nice. I will have to try this when I get home. Thanks for the suggestions.
