2012-02-07, 19:32
I did a new XBMC install and after Splash/Plymouth it loads up tty instead of XBMC's interface.
xinit xbmc-standlone leads to a white terminal
startx opens fluxbox (I think so).
xbmc@xbmc:~$ xinit xbmc-standlone
X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-29-server i686 Ubuntu
Current Operating System: Linux xbmc 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 19:00:09 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-29-generic root=UUID=4c24d7 6b-08ba-4f77-9b2c-f9413778c85b ro quiet splash
Build Date: 20 October 2011 03:05:54PM
xorg-server 2:1.7.6-2ubuntu7.10 (For technical support please see http://www.ubu ntu.com/support)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 7 10:57:45 2012
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/usr/lib/X11/xorg.conf.d"
No absolute path found for shell: xbmc-standlone
xbmc@xbmc:~$ startx
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-29-generic root=UUID=4c24d76b-08ba-4f77-9b2c-f9413778c85b ro quiet splash
xorg-server 2:1.7.6-2ubuntu7.10 (For technical support please see http://www.ubuntu.com/support)
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Feb 7 11:00:30 2012
Linux xbmc 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 19:00:09 UTC 2011 i686 GNU/Linux
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
linux-backports-modules-alsa-lucid-generic linux-backports-modules-wireless-2.6.35-lucid-generic linux-generic linux-headers-generic linux-image-generic
python-software-properties
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
cat xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder75) Thu Apr 22 11:44:23 PDT 2010
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Option "FlatPanelProperties" "Scaling = Native"
Option "HWCursor" "Off"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "True"
Option "DynamicTwinView" "False"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
grep EE /var/log/Xorg.0.log
(II) Loading extension MIT-SCREEN-SAVER
(EE) Feb 07 12:37:32 NVIDIA(0): Failed to get supported display device(s)
