2012-02-08, 17:17
2012-02-09, 07:34
Add it to a smart playlist or favorite, then add them to the submenu when you customize the home menu.
2012-02-09, 08:09
Is there also a way to delete items? For example, say I never use the Genres or Actors submenu of the movies library, could I somehow remove them to clean up the submenu a bit?
2012-02-09, 16:38
wd40s Wrote:Is there also a way to delete items? For example, say I never use the Genres or Actors submenu of the movies library, could I somehow remove them to clean up the submenu a bit?
Yeah, just disable them when you customize the home menu (press 's' on the home screen -> customize main menu. The instructions will be displayed on the top half of the screen).
2012-02-10, 18:40
In my opinion, this is one of the slickest features of Aeon Nox. The simplicity of setting up the menus while still being completely customizable is fantastic.
2012-02-14, 22:04
mbbransc Wrote:In my opinion, this is one of the slickest features of Aeon Nox. The simplicity of setting up the menus while still being completely customizable is fantastic.
Agree completely. Just wish I could access playlists to edit them from a submenu other than the videos menu as I disable that one.
2012-02-14, 22:08
You can add the playlist item to your favorites and add that to a submenu of your choice
