Full Version: [RELEASE] Random and last items smartplaylist script for Skins
Version 1.1.9 released
v1.1.9
- [Fix] If video has no stream details, resolution is set to blank
Has this script is still in development and I will add random and last properties for music, I think I won't put it on official repository, because of point 6.1 :
http://wiki.xbmc.org/index.php?title=Off...ry#Updates
Out of interest, if you use the property "propertie=SomePlayList" and do not set "type", is there anyway you could get if the type is Movie or Episode from the script. This makes a difference for me as the resulting list for Movies are shown as portrait while Episodes are landscape
Could you explain more, I don't understand your remark Sad
(2012-04-01, 12:31)mikebzh44 Wrote: [ -> ]Could you explain more, I don't understand your remark Sad
I've been redoing support for this script and have used
XBMC.RunScript(script.randomandlastitems,playlist=SomePlayList,method=Last,limit=10,unwatched=False,resume=False,propertie=MyFirstPlaylist)
And not added the option "type = Movie/Episode" so that type will be read from playlist file. Which works and is easier.
But when I want to display the output I now need to know if the playlist (Added by a user) was for Movie/Episode as they are displayed differently
Is there anyway I can get from the script what "type" (Movie/Episode) the playlist of " propertie=MyFirstPlaylist" is
No, but I can return a new property Type.
I'm busy today but I will make it for tomorrow Wink
@Mudislander :
If you want to test the new property Type, you just have to edit randomandlastitems.py code in the addon directory :
before :
def _setGeneralProperties ( _total, _watched, _unwatched ):
    global PROPERTIE
    global WINDOW
    # Set window properties
    _setProperty ( "%s.Count" % ( PROPERTIE ), str( _total ) )
    _setProperty ( "%s.Watched" % ( PROPERTIE ), str( _watched ) )
    _setProperty ( "%s.Unwatched" % ( PROPERTIE ), str( _unwatched ) )
After :
    global PROPERTIE
    global WINDOW
    global TYPE
    _setProperty ( "%s.Type" % ( PROPERTIE ), TYPE )
(2012-04-02, 10:42)mikebzh44 Wrote: [ -> ]@Mudislander :
Thanks Big Grin I'll give it a test
Edit Initial test, seems to work well, have cut out miles of code Smile
Found a small bug for you with the .Count property. Not an issue for me but you may want to look at it.
I have a playlist that returns 20 items, with 2 watched and 18 Unwatched - Which is correct. When I tell the script I only want to see the Unwatched items it returns 18 which is correct. However the .Count property stays at 20, with 2 watched and 18 Unwatched. Should it not now report 18 items with 0 watched.
As I said not an issue for me, as I'm happy it's reporting back on the whole playlist but you can decide what you want Smile
It's because .Count, .Watched and .Unwatched are based on Playlist and not on options resume= or unwatched=.
So everything is OK Wink
Has your tests are OK, I will put .Type property in next version.
All good, looking forward to next update, .Type property is a big help - Thanks
Hope this won't affect the old way.
No. You can specifie all the properties if you want.
Great thanx, btw just integrated your work in cirrus extended v2 and cirrus extended light.
See Here
Great work and great skins.
Version 1.2.0 released
v1.2.0
- [Add] Property .Type is returned. Value is Movie or Episode.
Helpfull if you use script with playlist and did not specifie type= parameter so script will get type from playlist.
