Full Version: [RELEASE] Random and last items smartplaylist script for Skins
I'm interresting what the difference is too?
(2012-05-13, 22:29)ronie Wrote: [ -> ]
(2012-05-13, 13:50)minimoe Wrote: [ -> ]I run nightlies and thumbs or posters don't show in the home screen when I associate a VPL with a home button.
it's an issue in recent xbmc builds:
http://trac.xbmc.org/ticket/13010
Problem seems to have been solved in today's nightly.
Hi everyone,
Very nice script.
I have a little question about it; can anyone help me ?
I use playlists (with genre) to show me the information of the last recently added tvshows within a widget in 'home' menu, just like in skin glass and skin confluence lite mod.
and, the thing is, is it possible, not to have the numbers of the seasons and episodes displayed before of the title of each episode and instead afterwards? or better, no to have them displayed at all ? I would just like to see in the information the episode title, is it possible?
Thanks everyone.
Thanks a bunch for this script. I found it quite annoying to have my documentaries in my main movie list, but thanks to your script I can just have my smart playlists show up in the main menu as if they were the main movie library Smile.
Merci beaucoup, and your English isn't as bad as you think it is Wink.
Edit: is there a way to have the script not circle through the recently added items as long as it's not selected? I believe the stock widget in Xbmc does not cycle between recently added items unless you click on them.
@sram : new release will be available before tonight to get correct episode title. I was due to JSON change :
http://forum.xbmc.org/showthread.php?tid...pid1049580
@.:B:. : It's not the script but the skin that circle in widget Wink
Version 1.2.3 released
v1.2.3
- [Fix] Episode title is now based on title and not on label because of some JSON changes :
(2012-05-21, 10:10)mikebzh44 Wrote: [ -> ]Script is on official repository :
http://xbmc.git.sourceforge.net/git/gitw...d3794e724d
Yahoo !!! Image
(2012-05-21, 07:56)mikebzh44 Wrote: [ -> ]@.:B:. : It's not the script but the skin that circle in widget Wink
Thanks, guess I have to find out how Aeon Nox does that then Smile.
Hi mikebzh44
Thx for your quick answer. thank you.
Hello Mikebzh44. i have errors in script, when randomize item, using latest xbmc frodo nightlies..please look my log, and try fix,
link for log download:
http://dl.dropbox.com/u/25170804/Randoni...t/xbmc.log
error in log
ERROR: Traceback (most recent call last):
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\script.randomitems\RandomItems.py", line 389, in <module>
Main()
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\script.randomitems\RandomItems.py", line 79, in __init__
self._fetch_musicvideo_info()
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\script.randomitems\RandomItems.py", line 217, in _fetch_musicvideo_info
fanart = item['fanart']
KeyError: ('fanart',)
07:15:34 T:12244 INFO: -->End of Python script error report<--
In XBMC Eden work fine, no errors messages..
Thanks for you job.
Wanilton
Sorry but this is not my script
You are running script.randomitems
And my script is script.randomandlastitems
does this work in frodo? i've tried installing the script and it doesn't show up anywhere
I haven't test it on Frodo but even when this script is installed, it's not displayed in any addon categorie.
If your skin use my script and run on Frodo, you can test if playlist widgets are displayed.
Has Fmronan (Glass skinner) have start to mod Aeon Nox with Glass on Frodo, I will ask him if he has any issue so far.
Runs just fine with Aeon Nox using Frodo
