Full Version: [RELEASE] Random and last items smartplaylist script for Skins
(2012-12-17, 22:03)butchabay Wrote: [ -> ]@mike
I get script failed ! lastandrandomitems.py
any idea?
Of course we do without a Debug Log Smile
Smile Ofcourse
http://pastebin.com/mkqnVwkF
Hope it helps, let me know if you need more infos.
Thanx ...
Ah yeah not really finished yet
Just comment out the lines that break it.
Hi Martijn,
here the lines i've found in my log.
Thanx.
http://pastebin.com/MBDnFf0y
Have patience, still cleaning up and adding Frodo improvements Smile
No problem martijn, take your time ... and watch another movie Smile
Guess what I've just found in the Repo Big Grin - Thanks guys, been waiting for this one
* Martijn hides before people start to complain
(2012-12-27, 11:45)Martijn Wrote: [ -> ]* Martijn hides before people start to complain
Big Grin !! As long as you still use the property "propertie" I should be allright
Edit Because you're so fond of snippets
Quote:CApplication::ExecuteXBMCAction : To XBMC.RunScript(script.randomandlastitems,playlist=special://skin/extras/Playlists/GenreChildren.xsp,method=Random,limit=10,unwatched=True,resume=False,propertie=HomePlayListSeven)
hmm i see "property" somehow got uppercase in the code. Will fix that.
Did change to correct spelling though Wink
propertie=H​omePlayListSeven -> property=H​omePlayListSeven
I just came back to start backtracking on this thread, 'cause I was getting a problem - it'll be the corrected spelling
@Martijn
don´t know if this is a bug from randomandlastitem or from aeon nox 4.0 skin.
I select for my playlist "Kinderfilme" latest movies, but i become random movies.
Here is a logfile.
http://xbmclogs.com/show.php?id=24345
Thanks for your great work.
Eisi
(2012-12-27, 14:00)Martijn Wrote: [ -> ]hmm i see "property" somehow got uppercase in the code. Will fix that.
Yes, sorry for my english
One property, two properties
Nice job Martijn.
I think I can migrate from Eden / Aeon Nox 3.6.1 to Frodo / Aeon Nox 4.0 now Big Grin
is there a version for frodo out there..and if yes where can i find it?becuse aeon nox 4 will not show my playlist widgets..and i have skin widget install..but why does it not work if it is the same thing?
@coolio99
you could get a version here
http://mirrors.xbmc.org/addons/frodo/
Eisi
