2013-04-30, 04:56
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
2013-05-02, 21:26
Hi dudes, just wondering, can Property(RunTime) be added for tv shows / episodes ?
Thanx
Thanx
2013-05-04, 13:06
Hi Mike, i have a question,
is it possible to filter the result with ratings ?
e.g
return 10 random movies with ratings above 6.0 ?
I'm trying to make some kind of recommendations for high-rated movies
e.g
2013-05-04, 13:19
Create a smart playlist with all your movies with rating >= 6.0, then use that playlist and return random results.
2013-05-04, 14:03
(2013-05-04, 13:19)`Black Wrote: [ -> ]Create a smart playlist with all your movies with rating >= 6.0, then use that playlist and return random results.
Thanks i just remembered your answer from other thread lol
2013-05-04, 21:31
(2013-05-02, 21:26)butchabay Wrote: [ -> ]Hi dudes, just wondering, can Property(RunTime) be added for tv shows / episodes ?
Thanx
Sure but I'm on holidays ;)
Remind me after monday 13th may.
2013-05-04, 21:43
Would it be possible to also allow random selection of tv shows, not tv show episodes?
I'm using it with Aeon Nox to display random fanart background for my smart-playlist-powered home menu items. My problem is that I've got one show with nearly as many episodes as all other shows together, so it's fanart is displayed about 50% of the time.
2013-05-06, 03:55
Hi Mike, just a quick question, is this the correct way to call your script?
(vpl1.path is the path to the first video playlist)
It's supposed to call a widget that shows Movies with rating > 6
And the script runs when one of the left menu is on focus..
If the number of movie is one everytime the script runs, then the limit is 1 correct?
I set the parameters like this :
I can't get it to work though..
This is the complete thread..
http://forum.xbmc.org/showthread.php?tid...pid1413793
PHP Code:
<onload condition="System.HasAddon(script.randomandlastitems) + !IsEmpty(skin.string(vpl1.path))">RunScript(script.randomandlastitems,limit=1,method=Random,playlist=special://masterprofile/playlists/video/Recommended_Barat.xsp,menu=Menu51)</onload>
PHP Code:
<include name="rec_contentvpl1">
<control type="panel" id="510"><!--- Playlist de Video 1 Recommended -->
<include condition="SubString(skin.string(menu),vertical)">panel_video_v</include>
<include condition="SubString(skin.string(menu),horizontal)">panel_video_h</include>
<visible>Container(9000).HasFocus(31)</visible>
<include>panel_videolayout</include>
<content>
<item>
<label>$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Title)]</label>
<label2>$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Tagline)]</label2>
<icon>$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Art(poster))]</icon>
<property name="Fanart">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Art(fanart))]</property>
<property name="Genre">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Genre)]</property>
<property name="Runtime">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Runtime)]</property>
<property name="Rating">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Rating)]</property>
<property name="Plot">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Plot)]</property>
<property name="Year">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Year)]</property>
<property name="Mpaa">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.MPAA)]</property>
<onclick>Skin.SetString(custom_play,$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Play)])</onclick>
<onclick>Skin.SetString(custom_trailer,$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Trailer)])</onclick>
<onclick condition="!IsEmpty(Window(0).Property(PlaylistLastMovieMenu51.1.Trailer))">ActivateWindow(623)</onclick>
<onclick condition="IsEmpty(Window(0).Property(PlaylistLastMovieMenu51.1.Trailer))">$INFO[Window(0).Property(PlaylistLastMovieMenu51.1.Play)]</onclick>
<visible>!IsEmpty(Window(0).Property(PlaylistLastMovieMenu51.1.Title))</visible>
</item>
</content>
</control>
</include>
2013-05-06, 12:03
If you call it with method=Random, the properties are PlaylistRandomMovieMenu51.
2013-05-06, 12:30
(2013-05-06, 12:03)`Black Wrote: [ -> ]If you call it with method=Random, the properties are PlaylistRandomMovieMenu51.
Thanks black, changed it, but it still doesn't fix the problem..
It's still showing blank panel
Is everything else on my thread correct?
2013-05-06, 17:37
Sorry, I'm on holydays. If you know how to do, put some print of properties in python script to see what script return.
2013-05-07, 09:48
Hi all,
I'm playing with the resume = True/False | resume=True to filter only partially watched items parameter but it's unclear for me how (and which) parameters to use.
If i look at example i think it should look like this
XBMC.RunScript(script.RandomAndLastItems,resume=True,playlist=special://masterprofile/playlists/video/children.xsp,menu=Menu1)
I removed type since it is read from playlist according wiki, also removed limit since it would only show 1 item (and default would be 10) and not sure if Method is needed for it? If it's needed i would say it should be set to Last?
2013-05-08, 15:53
Hi, i kinda figured out the last problem..
But i run into another prob..
Just wanna ask 1 quick question :
Is it possible to run both random and last at the same time ?
The bottom panel in the skin will run random and the upper will run last
something like this :
each uses different playlist... and both have same condition, onfocus
PHP Code:
<include name="RecommendedFocus">
<onfocus condition="Container(9000).HasFocus(31) + !IsEmpty(Container(9000).ListItem.Property(RunScript_OnFocus)">RunScript(script.randomandlastitems,limit=12,method=Last,playlist=$INFO[Skin.String(vpl1.path)],menu=Menu31)</onfocus>
<onfocus condition="Container(9000).HasFocus(31) + !IsEmpty(Container(9000).ListItem.Property(RunScript_OnFocus)">RunScript(script.randomandlastitems,limit=1,method=Random,playlist=special://masterprofile/playlists/video/Recommended_Barat.xsp,menu=Menu31)</onfocus>
<visible allowhiddenfocus="true">false</visible>
</include>
2013-05-13, 13:01
2013-05-13, 14:07
Thanks for reminding me
You can try the latest release from GITHUB :
https://github.com/XBMC-Addons/script.ra...dlastitems
Property Runtime is returned for Episodes / TV shows.
No bugs on my side but I just put some debug print in my log, tell me if on the skinner side, every thing is OK.
