Full Version: [RELEASE] Random and last items smartplaylist script for Skins
There is no ERROR related to this script in the 2 debug log :S
Yeah that's the one that works, but move the same playlist to the skin folder and then it doesn't work.
So move your playlist in skin folder and get the error in the debug log before to post it on xbmclogs Wink
@Mudislander
Post the line calling the script and the playlist so i can test it and report back.
(2014-01-07, 22:39)mikebzh44 Wrote: [ -> ]So move your playlist in skin folder and get the error in the debug log before to post it on xbmclogs Wink
Sorry misread your post, thought you only said 2nd log had no error Blush
@butchabay thanks for the offer - Can I take a rain check on that.
Hi all,
I've tried to integrate the current git version of the script to my confluence-mod. For Movies it is working as expected, but with Audio I have problems.
Is there a bug in the script, or have I done something wrong to integrate?
Here the onload Part of Home.xml
PHP Code:
XBMC.RunScript(script.randomandlastitems,limit=6,method=Last,playlist=special://skin/playlists/Audiobooks.xsp,menu=Menu2)
The Audiobooks Playlist:
PHP Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="albums">
    <name>Audiobooks</name>
    <match>one</match>
    <rule field="genre" operator="contains">
        <value>Audio Book</value>
    </rule>
        <value>Audiobook</value>
    </rule>
        <value>audiobook</value>
    </rule>
        <value>audio book</value>
    </rule>
        <value>AUDIOBOOK</value>
    </rule>
        <value>AUDIO BOOK</value>
    </rule>
    <order direction="ascending">album</order>
</smartplaylist>
And as example a snippet from
PHP Code:
<item>
label>$INFO[Window.Property(PlaylistLastMusicMenu2.1.Title)]</label>
label2>$INFO[Window.Property(PlaylistLastMusicMenu2.1.Artist)]</label2>
onclick>PlayList.Clear</onclick>
onclick>PlayMedia(&quot;$INFO[Window.Property(PlaylistLastMusicMenu2.1.Play)]&quot;)</onclick>
icon>-</icon>
thumb>$INFO[Window.Property(PlaylistLastMusicMenu2.1.Thumb)]</thumb>
item
Snippet of xbmc.log
PHP Code:
ERROREXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
NOTEIGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('artistid',)
Traceback (most recent call last):
File "/home/pi/.xbmc/addons/script.randomandlastitems/randomandlastitems.py"line 851in <module>
_getAlbumsFromPlaylist()
File "/home/pi/.xbmc/addons/script.randomandlastitems/randomandlastitems.py"line 532in _getAlbumsFromPlaylist
                                                _artistid
_result[0]['artistid']
KeyError: ('artistid',)
End of Python script error report<--
The used XBMC Version is 12.2
The used script Version is 2.2.0
Does anyone know a solution for this?
Thanks in advance
Could you share (dropbox, rapidshare, ...) your MyMusic32.db ?
It's because the song in album "Tron hörspiel" did not have artist (in MP3 tag) :
As you can see, field strArtists is blank :
Your other audiobooks, such as Inferno, are OK :
Field strArtists is OK for every song :
Sakrileg is fine too but you will have the same problem with ID4 Idependance Day :
Thanks, for your fast help, thats it!
First of all: Thanks for all the Effort invested in this Script.
Works fine on my End (now)!
Request:
Would it be possible to add "Recent/inProgress" as method?
At the Moment i use a separate/additional Smartplaylist to show me recent (inProgress) Movies, in the Skin Widged.
PHP Code:
<rule field="inprogress" operator="true" />
It would be cool if I just could use this Script to show me Recent items of a Smartplaylist, insted to copy-paste a existing Smartplaylist, and add in one of them the additional rule. to finaly show it in the widget.
Regards.
No, you have to create separate smart playlists.
Thanks for your reply.
Think ",method=Last,resume=True" shuld do the job for me, wll give it a try. Thanks.
Hi Mike, got a question, any idea what this error is about?
I'm trying to create Latest/random genre movies, e.g latest action movies
09:11:56 T:6936   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'nodeValue'
                                              File "S:\Users\Administrator\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 723, in <module>
                                                _parse_argv()
                                              File "S:\Users\Administrator\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 644, in _parse_argv
                                                _getPlaylistType ();
                                              File "S:\Users\Administrator\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 57, in _getPlaylistType
                                                _name = _doc.getElementsByTagName('name')[0].firstChild.nodeValue.encode('utf-8')
                                            AttributeError: 'NoneType' object has no attribute 'nodeValue'
I'm trying to mod Ace's main menu with genres,
the playlist is like this :
    <onload condition="System.HasAddon(script.randomandlastitems) + !IsEmpty(skin.string(fav101.path)) + SubString(skin.string(mfvpl101_list),latest)">RunScript(script.randomandlastitems,limit=12,method=Last,playlist=$INFO[Skin.String(fav101.path)],menu=Menu101)</onload>
    <onload condition="System.HasAddon(script.randomandlastitems) + !IsEmpty(skin.string(fav101.path)) + SubString(skin.string(mfvpl101_list),random)">RunScript(script.randomandlastitems,limit=12,method=Random,playlist=special://masterprofile/playlists/video/Film_Action.xsp,menu=Menu101, daemon=True)</onload>
The playlist works correctly when i open it.
Seems like the "latest" method only reads path, not playlist.
While genre can not be defined with path..
When i force it to read from movie.db, like this:
skin.ace.fav101.path">ActivateWindow(10025,videodb://1/1/1/,return)
it gives me this error
11:37:36 T:5108   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.IOError'>
                                            Error Contents: (22, "invalid mode ('rb') or filename", 'ActivateWindow(10025,videodb://1/1/1/,return)')
                                                _parse_argv()
                                              File "S:\Users\Administrator\AppData\Roaming\XBMC\addons\script.randomandlastitems\randomandlastitems.py", line 46, in _getPlaylistType
                                                _doc = parse(xbmc.translatePath(PLAYLIST))
                                              File "S:\Program Files\XBMC\system\python\Lib\xml\dom\minidom.py", line 1918, in parse
                                                return expatbuilder.parse(file)
                                              File "S:\Program Files\XBMC\system\python\Lib\xml\dom\expatbuilder.py", line 922, in parse
                                                fp = open(file, 'rb')
                                            IOError: (22, "invalid mode ('rb') or filename", 'ActivateWindow(10025,videodb://1/1/1/,return)')
Onclick method works for above path so it's not syntax error
<onclick>ActivateWindow(10025,videodb://1/1/1/)</onclick>
Anyone successfully implemented thie script with genre?
[quote='denywinarto' pid='1617925' dateline='1391397832']
                                                _parse_argv()
Please paste here the content of your XSP file.
(2014-02-03, 10:42)mikebzh44 Wrote: [ -> ]Hi Mike, got a question, any idea what this error is about?
                                                _parse_argv()
<smartplaylist type="movies">
    <name></name>
    <match>all</match>
    <rule field="genre" operator="is">
        <value>Action</value>
    </rule>
</smartplaylist>
It works correctly on playlist menu..
