Full Version: [RELEASE] Random and last items smartplaylist script for Skins
Only for fun. I guess this is really bad:
20:59:16 T:6608   DEBUG: Random and Last items script: Loading PlaylistRandomEpisodeMenu31 started at 2014-05-20 20:49:20 and take 9.927m
Big Grin
OK, the script took 9 minutes to run but :
- which skin are you using ?
- Frodo ? Gotham ?
- how many time the script is called at init ?
- how many TV shows ? Episodes ?
- smart playlist based on TV shows or episodes ? Episode is worth.
Hello Mike,
- used Ace skin to test plugin because it's already there
- XBMC version is Gotham 13.1 somewhere between Beta 1 and 2
- briefly checked Ace skin and it seems to call script 3 times in <onload>, for latest, random and inprogress
- currently I have 3458 TV Shows in library and 49178 episodes (main reason I guess Smile)
- playlist is TV Show based (tag based)
Btw I didn't want to sound ungrateful, I'm already aware of XBMC performance with my library side so I didn't expected miracles.
So sorry if it sounded wrong, it wasn't meant to Smile
No bother.
I know that this script is not optimized for huge library like your (nearly 50.000 episodes !!!).
You can use Aeon Nox 5 as BigNoid use a different way to populate widgets :
http://forum.xbmc.org/showthread.php?tid...pid1637215
Or use this workaround :
http://forum.xbmc.org/showthread.php?tid...pid1628765
Thanks for the hints.
I'll look around for some working solution for my library size Smile
Hi all. Just registered to say thank you to all contributors who are doing an amazing job offering new and better ways of customizing the already great XBMC.
Now for my question:
I'm using the latest Aeon Nox 5 on Gotham xbmc on Windows 7. I tried to install several of the new versions (2.2.0 to 2.2.2) of this script, but somehow xbmc does not let me install it. Is there a compatibility problem? Is this script known to work with Gotham and Aeon Nox? I googled for hours, but could not find a final answer to my question. Thanks in advance.
This script work on Gotham but Aeon Nox 5 does not use it anymore :
Hi Mike
Thank you for the quick response. That's a shame, as I find your script much better than Aeon Nox's solution. I don't like those DVD cases, I would much prefer Fanart as background. Need to post over there then : )
I'm getting an error when using the Hybrid skin with a smart playlist as a homepage item; http://pastebin.com/wHWeFWyE might help you work out why. Unsure whether the issue is with the skin or the script, however IRC directed me to post here, so I shall.
Oddly, when I use a skin default playlist, but with other settings identical, it works without issue. As yet I'm unable to see how or why, will update the post if I find out more.
Cheers.
Update: removing the sort order entirely from the playlist, prevents the error from occuring.
Could you share your XSP file (smart playliste) with and without sort order ?
And post your log file to xbmclogs.com, I can't access pastbin.com at my office (not allowed by the firewall :S )
I to am getting an error when trying to set up a playlist on Aeon nox 4.1.9. Which is why I think its not populating the widget when added. I saw on the wiki that here is a 13.1 available in the repo but can't find it.
If you are toalking about XBMC Gotham 13.1, you can download it from here :
http://xbmc.org/download/
If you get an error with my script, please turn on debug mode in XBMC settings then reproduce the error and share your xbmc.log file on http://xbmclogs.com.
(2014-07-21, 07:11)mikebzh44 Wrote: [ -> ]If you are toalking about XBMC Gotham 13.1, you can download it from here :
I'll get a debug log posted when I'm off work.
Would really love to use this in a skin I'm developing, but after hours trying everything I could think of I just can't seem to get it to work.
I have unzipped the script to the addons folder (both in ..programs(x86)/XBMC and ..appdata/roaming/xbmc).
I am trying to use the following to load the script (in the applicable window). I don't want to use a playlist so haven't specified one and just want to use it to display random albums. The only thing I was really unsure of is what "menu" refers to? This syntax doesn't seem to be formally used anywhere else in XBMC skinning so I can't really work out what it means.
<onload>XBMC.RunScript(script.RandomAndLastItems,limit=16,type=Music,method=Random,menu=Menu1)</onload>
Anyway, as a stated for ten I am trying to show the first two random albums using:
<onclick>$INFO[Window(Home).Property(RandomAlbum.1.Play)]</onclick>
<icon>$INFO[Window(Home).Property(RandomAlbum.1.Thumb)]</icon>
But nothing is displayed.
The debug log does not report any issues - just lists the script as installed.
I am using Gotham 13.1. Any help greatly no appreciated!
