Full Version: [MQ3] [Eden Beta3] Movies and TV Show keep showing same folder and settings
First I upgraded Eden Beta 2 (with MQ3 1.2.2) to Beta 3, then I already had the problem that selecting either Movies or TV Show on the main menu kept showing the same folder and settings.
The be clear:
- I select movies and set it to my movie collection with a showcase view
- then go back to the main menu and select TV shows
- It will then show the my movie collection with a showcase view
- Then I set it to my series collection with banner view
- then go back to the main menu and select Movies
- It will show my series collection with banner view
etc.
Since I also had some database problems I did a full reinstall (deleted XBMC roaming directory)
The same problem occurs then also after I reset all settings (Confluence skin is ok).
Any idea what I am doing wrong? or is it a bug?
I has no problem with movies view and tv show view on latest MQ3 1.2.2 and Eden beta 3
tetsu81vn Wrote:I has no problem with movies view and tv show view on latest MQ3 1.2.2 and Eden beta 3
Unfortunately I have not been able to get it to work, I always get the same view for TV Shows and Movies.
Could you tell me you settings:
normal, lite etc.
pvr yes/no
amber etc.
btw I am on Windows 7 Ultimate 32bit
