2012-07-06, 21:46
People, I can confirm setting the <fpsdetect>2</fpsdetect> as above did solve the issue! However, sometimes it doesn't switch while I don't go and set the deinterlace option to "auto" or some other option.
After some 5 seconds (sometimes more), it blacks the screen for a second or two and then switch to the 23.97 refresh rate and then I have a pretty smooth playback. :-D
Just curiosity... How as this in XBMCLive Dharma? I had it before running on Ubuntu 10.04 and it worked flawlessly. I didn't have to set this advanced setting and I didn't see it switching the refresh rate as well.
Well, at least now I can see the DVDs and ISOs that I have smootlhy... I was just thinking why this happens. The Indiana Jones DVDs ISOs I have are 23.97 fps (NTSC). See the mediainfo:
Why such awkward frame rate? around 45? Maybe setting the <adjustrefreshrate> and its <override> would have a better experience rather than using the fpsdetect? What fpsmin / fpsmax would you guys recommend to try with the samples I've provided above?
Looking forward any clarifications on that, but I'm already happen to be able to watch them without the BAD stutter I had.
General
Complete name : /home/gpborges/.gvfs/Indiana.Jones.e.a.Ăšltima.Cruzada.%281989%29.iso/VIDEO_TS/VTS_06_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 1s 34ms
Overall bit rate mode : Variable
Overall bit rate : 0 bps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Duration : 1s 34ms
Bit rate mode : Variable
Bit rate : 0 bps
Maximum bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Compression mode : Lossy
Bits/(Pixel*Frame) : 982.549
Stream size : 1 012 MiB (99%)
Color primaries : SMPTE 170M
Transfer characteristics : SMPTE 170M
Matrix coefficients : SMPTE 170M
Audio #1
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 256ms
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 14.0 KiB (0%)
Audio #2
ID : 189 (0xBD)-129 (0x81)
Format : AC-3
Duration : 320ms
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 7.50 KiB (0%)
Text #1
ID : 189 (0xBD)-32 (0x20)
Format : RLE
Format/Info : Run-length encoding
Text #2
ID : 189 (0xBD)-33 (0x21)
Format : RLE
Text #3
ID : 189 (0xBD)-34 (0x22)
Format : RLE
Text #4
ID : 189 (0xBD)-35 (0x23)
Format : RLE
Menu
