2012-02-11, 20:49
I run Ubuntu 11.10
Tvheadend 2.12 , installed form deb.
3.1.5 kernel, added manually form deb (same results with 3.0.0.15, delivered with distro, though)
Avermedia PCI pure analog (M135A) videocard.
I try to setup this PCI card as a backend for XBMC, but I cannot configure the card.
I open the config window in browser, correctly enter pass and username, and try to go Configuration>TV adapters
When I click the drop-down menu, it is empty, and no choices appear. First I thought the card is not working, but my dmesg says otherwise(or I think so)
Here is the output of dmesg:
[ 6.178736] saa7130/34: v4l2 driver version 0, 2, 17 loaded
[ 6.178775] saa7134 0000:04:01.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 6.178780] saa7133[0]: found at 0000:04:01.0, rev: 209, irq: 18, latency: 84, mmio: 0xfdaff000
[ 6.178786] saa7133[0]: subsystem: 1461:f11d, board: Avermedia PCI pure analog (M135A) [card=149,autodetected]
[ 6.178798] saa7133[0]: board init: gpio is 40000
[ 6.452181] input: saa7134 IR (Avermedia PCI pure as /devices/pci0000:00/0000:00:1e.0/0000:04:01.0/rc/rc0/input4
[ 6.452263] rc0: saa7134 IR (Avermedia PCI pure as /devices/pci0000:00/0000:00:1e.0/0000:04:01.0/rc/rc0
[ 6.604046] saa7133[0]: i2c eeprom 00: 61 14 1d f1 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[ 6.604068] saa7133[0]: i2c eeprom 10: ff ff ff ff ff 20 ff ff ff ff ff ff ff ff ff ff
[ 6.604087] saa7133[0]: i2c eeprom 20: 01 40 01 32 32 01 01 43 88 ff 00 56 ff ff ff ff
[ 6.604107] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604126] saa7133[0]: i2c eeprom 40: ff 22 00 c0 96 ff 03 30 15 00 ff ff ff ff ff ff
[ 6.604146] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604165] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604184] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604207] saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604216] saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604225] saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604234] saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604243] saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604252] saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604261] saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.604270] saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 6.642365] input: MCE IR Keyboard/Mouse (saa7134) as /devices/virtual/input/input5
[ 6.717417] rc rc0: lirc_dev: driver ir-lirc-codec (saa7134) registered at minor = 0
[ 10.372160] saa7133[0]: registered device video0 [v4l2]
[ 10.372256] saa7133[0]: registered device vbi0
[ 10.372330] saa7133[0]: registered device radio0
[ 10.454801] saa7134 ALSA driver for DMA sound loaded
[ 10.454827] saa7133[0]/alsa: saa7133[0] at 0xfdaff000 irq 18 registered as card -2
Any other ideas how to configure XBMC with different, working backend. MythTV was way too confusing for me.
