Full Version: Working Shoutcast Plugin for latest Eden Nightlies?
Hi Folks,
I used to listen to shoutcast using izenls shoutcast plugin for the last months. But it seems the plugin isn't compatible with the latest Eden nightlies, or shoutcast changed some stuff again.
I can't browse genres anymore. All I get is an empty directory listing ....
Are there any alternatives for shoutcast?
boba
https://github.com/downloads/christiansc...-1.2.0.zip
This works for me with Eden beta 3 on Windows.
Hey,
thanks for the info, what features does that plugin have? Most important to me with izenls plugin was that you could sort by popularity or number of listeners, can you do this with that plugin as well?
boba
you just made me a very happy boy!! Working for XBMC 11 (compiled march 21,2012)
Anyone still working on this? be cool if it saved searches.
The link is dead. What a bummer. Confused
(2012-08-26, 08:02)Skram0 Wrote: [ -> ]The link is dead. What a bummer. Confused
Try this link, I can't vouch for it though: https://github.com/christian-schulze/XBM...ast-plugin
Edit: I can vouch for it now, works great, although lists stations in order of descending bitrate instead of (what I would prefer) descending listener number.
Will this SHOUTCAST plugin work with the LastFM slide show artist artwork viewer tool? On other Artwork viewing tools?
v1.3.0 breaks on the latest Frodo nightlies.
01:47:23 T:4729790464   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'module' object has no attribute 'output'
                                              File "/Users/Kris404/Library/Application Support/XBMC/addons/christian-schulze-XBMC-shoutcast-plugin-91baeb3/default.py", line 181, in <module>
                                                PLAY(params["tunein"], play)
                                              File "/Users/Kris404/Library/Application Support/XBMC/addons/christian-schulze-XBMC-shoutcast-plugin-91baeb3/default.py", line 67, in PLAY
                                                log("PLAY URL: %s" % url)
                                              File "/Users/Kris404/Library/Application Support/XBMC/addons/christian-schulze-XBMC-shoutcast-plugin-91baeb3/default.py", line 141, in log
                                                xbmc.output("### [%s] - %s" % (__addonname__,msg), level = xbmc.LOGDEBUG)
                                            AttributeError: 'module' object has no attribute 'output'
01:47:23 T:4729790464    INFO: Python script stopped
01:47:23 T:4729790464   DEBUG: Thread XBPyThread 4729790464 terminating
Anyone know how to fix this?
Here's the xbmc.log with Debug turned on.
Thanks,
Why not try my Radio Addon?
It is no shoutcast browser bot most stations should be present.
(2012-10-19, 14:58)sphere Wrote: [ -> ]Why not try my Radio Addon?
Cool, will try tonight.
Can you add custom Shoutcast URLs using the addon?
