Totally new to XBMC running on Apple TV 2. I see the fantastic pictures posted of the Aeon skin and I am totally lost on how to even start to get mine to look like some of the ones that I have seen.
Has anyone posted their modified skins as a whole zip or in a repo that can just be loaded into the ATV2?
many are available through the xbmc addon repo:
System > Add-ons > Get add-ons > XBMC.org add-ons > Skin
I have looked at those and unless I am missing something those are not heavily modded to look like the pictures I see in some of the posts here on the forums and unfortunately I am not gifted enough to make my ATV2 on xbmc look like they have it looking.
Its not really modding.
Just go to System>Skin and change everything you want.
But I think for an ATV2 Aeon skins are not the best but you can always try and if they are to slow take a look at reFocus should run smooth on every system and looks nice.
well, it might help to tell us which pictures you've seen
As TeKo suggested I looked at the reFocus skin and would like to duplicate how that looks and how it is set up.
rahjer Wrote:As TeKo suggested I looked at the reFocus skin and would like to duplicate how that looks and how it is set up.
There's no easy way of copy/pasting the settings from others
It's best to just try all settings yourself.
ronie, what do you mean "scan to the Library"? I am using an Apple TV2, not a computer. I already have stuff on my PC that I would like to stream to the Apple TV2 from my computer.
Quote:ronie, what do you mean "scan to the Library"? I am using an Apple TV2, not a computer. I already have stuff on my PC that I would like to stream to the Apple TV2 from my computer.
Did you follow the links that ronie provided? That's why they were posted, to answer the questions you have.
Thanks. Will give it a try.
