Full Version: [LINUX] Audio Problems with Eden Beta 3 and Ubuntu 11.10
Pages: 1 2 3 4
Hi everybody,
I just installed a fresh Ubuntu 11.10 on my Acer Revo 3610. I installed Eden Beta 3 and everything works, except audio in movies. Menu audio works fine using HDMI output, but everytime I start a movie (does not matter if it's DTS/AC3 or any other format, even MP3 does not work) there is a message: Unable to initialize your sound device. Check audio settings (I hope I translated correctly from my german system).
I tried to uninstall pulse-audio, tried several tweaks that I found in some forums....nothing....
A aplay -l gives me the
Karte 0: NVidia [HDA NVidia], Gerät 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 0: NVidia [HDA NVidia], Gerät 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
  Sub-Geräte: 1/1
Karte 0: NVidia [HDA NVidia], Gerät 3: HDMI 0 [HDMI 0]
  Sub-Geräte: 1/1
mephisto@faustus:~$
aplay -D plughw:0,3 /usr/share/sounds/alsa/Front_Center.wav
does work....
I already tried to set the device for audio/passthrough in XBMC to plughw:0,3, but again...nothing.
One (maybe?) weird thing: It does not matter what audio device I chose from the menu: The menu sounds works like a charm: always...
Do you have any hints? I really love Eden's AirPlay feature, I want to use it here ;-)
Thanks,
Jan
What does aplay -L provide?
mephisto1980 Wrote:Hi everybody,
  Sub-Geräte: 1/1
  Sub-Geräte: 1/1
  Sub-Geräte: 1/1
mephisto@faustus:~$
does work....
Thanks,
Jan
giftie Wrote:What does aplay -L provide?
mephisto@faustus:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
nvidia_hdmi
pulse
    Playback/recording through the PulseAudio sound server
front:CARD=NVidia,DEV=0
    HDA NVidia, ALC662 rev1 Analog
    Front speakers
surround40:CARD=NVidia,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=NVidia,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=NVidia,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=NVidia,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=NVidia,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=NVidia,DEV=0
    HDA NVidia, ALC662 rev1 Digital
    IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
dmix:CARD=NVidia,DEV=0
    Direct sample mixing device
dmix:CARD=NVidia,DEV=1
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=0
    Direct sample snooping device
dsnoop:CARD=NVidia,DEV=1
dsnoop:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=0
    Direct hardware device without any conversions
hw:CARD=NVidia,DEV=1
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=0
    Hardware device with all software conversions
plughw:CARD=NVidia,DEV=1
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
Thanks for any help!
Jan
Try setting the device as: plughw:CARD=NVidia,DEV=1
giftie Wrote:Try setting the device as: plughw:CARD=NVidia,DEV=1
Ok, done that. This time I got no error message, but still no sound. For DEV=3, I still got the message (failed to initialize...), for DEV=0 and DEV=1 no message but also no sound....
Any more hints?
with beta3 I had audio problems too. Try this custom setting
alsa:hdmi:CARD=NVidia
P.S. remember to unmute nvidia output with
alsamixer -c <card_number>
Btw: I tried to track the exception in the logs, this is what I found:
19:49:09 T:2730109808   ERROR: Initialize - failed to open custom device hdmi:CARD=NVidia,DEV=3,AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 (error:No such file or directory), retry with default hdmi:CARD=NVidia,DEV=3
19:49:09 T:2730109808   ERROR: Initialize - pcm_open_lconf, alsa error: -2 - No such file or directory
19:49:09 T:2730109808   ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
Maybe that helps...hopefully...
joethefox Wrote:with beta3 I had audio problems too. Try this custom setting
Again: Exception.....
Here the log:
20:05:13 T:2856278896   ERROR: Initialize - failed to open custom device hdmi:CARD:NVidia,AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 (error:No such device), retry with default hdmi:CARD:NVidia
20:05:13 T:2856278896   ERROR: Initialize - pcm_open_lconf, alsa error: -19 - No such device
20:05:13 T:2856278896   ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
mephisto1980 Wrote:Ok, done that. This time I got no error message, but still no sound. For DEV=3, I still got the message (failed to initialize...), for DEV=0 and DEV=1 no message but also no sound....
Any more hints?
Focus on plughw:CARD=NVidia,DEV=1 and plughw:CARD=NVidia,DEV=0 and no sound. To check if the channels are muted/unmuted, with
alsamixer -c 1
you should see the HDA NVidia mixer with four squares. Inside the squares there are "MM"(muted) or "OO"(unmuted)?
I can only execute
alsamixer -c 0
and here everything is unmuted (I did that a long time ago ;-) )
With
alsamixer -c 1
I get a error: "Invalid card number: 1" (again translated from german)
joethefox Wrote:Focus on plughw:CARD=NVidia,DEV=1 and plughw:CARD=NVidia,DEV=0 and no sound. To check if the channels are muted/unmuted, with
alsamixer -c 1
my mistake, I've two soundcard... Blush
So, if with alsamixer -c 0 the sound card in the top left corner is "HDA NVidia" and everything is unmuted... I don't know what else to try, sorry.
Maybe I should buy a second soundcard as well ;-)
Thanks for your help!
Ok, now I removed (purged) pulseaudio*...dada: No sound in menu *and* no sound in movies.
The error message that I get is:
20:51:19 T:2503191408   ERROR: Initialize - failed to open custom device plughw:0,3,AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 (error:No such file or directory), retry with default plughw:0,3
20:51:19 T:2503191408   ERROR: Initialize - pcm_open_lconf, alsa error: -16 - Device or resource busy
20:51:19 T:2503191408   ERROR: Unable to open audio mixer
20:51:19 T:2503191408   ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
So, now the device is busy?
Any ideas? I read about dmix to enable multiple sound processes.....but I have no idea how to configure....
23:04:17 T:2584734576   DEBUG: Found 4 fbconfigs.
23:04:17 T:2584734576   DEBUG: Using fbconfig index 0.
23:04:17 T:2593127280   ERROR: Initialize - pcm_open_lconf, alsa error: -16 - Device or resource busy
23:04:17 T:2593127280   DEBUG: SetActiveDevice - SetActiveDevice from 2 to 1
23:04:17 T:2593127280   DEBUG: RemoveActiveDevice - Removing device 2
23:04:17 T:2771897200   DEBUG: set caching from pvr to done. audio (1) = 8. video (1) = 6
23:04:17 T:2593127280   ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
23:04:17 T:2593127280   DEBUG: RemoveActiveDevice - Removing device 1
23:04:17 T:2593127280   DEBUG: SetActiveDevice - SetActiveDevice from 0 to 2
23:04:17 T:2593127280   DEBUG: RemoveActiveDevice - Removing device 0
23:04:17 T:2593127280   DEBUG: CNullDirectSound::Initialize - Channels: 2 - SampleRate: 48000 - SampleBit: 16 - Resample false - IsMusic false - IsPassthrough 0 - audioDevice: plughw:0,7
23:04:17 T:2593127280   DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
23:04:17 T:2771897200   DEBUG: CDVDPlayer::SetCaching - caching state 0
23:04:17 T:2771897200   DEBUG: CDVDPlayer::HandleMessages - player started 1
23:04:17 T:2771897200   ERROR: Get - failed to get stream
I have this problem too.
I have set custom device to plughw:0,7 which works most of the time, but sometimes when opening a video it fails resulting in no audio until I do system reboot to get it working again.
What if you do this:
sudo chmod -R a+rwX /dev/snd
Pages: 1 2 3 4
