2012-02-12, 21:15
I have an issue.
I like to use the setting <playlistasfolders>false</playlistasfolders> with shuffle on playlist to auto shuffle videos in folders.
However my issue is if i create a share and try to play it directly from the video mount, it won't play.
Debugging shows:
However if i enter one of those shares, and then hit play on a folder, it works perfectly.
I wonder why i can't play folders directly from the sources folder.
Also this isn't an issue in Eden11 since it treats all source shares as they are mounted in /files/ which means it thinks its a subfolder and not the root.
Someone who can help me would be great, i can't figure it out.
I have an issue.
Debugging shows:
20:08:39 T:3079427968 M:1454907392 DEBUG: OnKey: 234 pressed, action is Play
20:08:39 T:3079427968 M:1454907392 DEBUG: LIRC: Update - NEW at 81856:000000037ff07be9 00 Play mceusb (Play)
20:08:40 T:2996566896 M:1454907392 DEBUG: Thread 2996566896 terminating (autodelete)
20:08:40 T:3079427968 M:1454907392 DEBUG: LIRC: Update - NEW at 82256:000000037ff07be9 00 Play mceusb (Play)
20:08:40 T:3079427968 M:1454907392 DEBUG: OnKey: 234 pressed, action is Play
20:08:40 T:3079427968 M:1454915584 DEBUG: LIRC: Update - NEW at 82640:000000037ff07be9 00 Play mceusb (Play)
20:08:40 T:3079427968 M:1454915584 DEBUG: OnKey: 234 pressed, action is Play
20:08:40 T:3020938096 M:1454915584 DEBUG: Thread 3020938096 terminating (autodelete)
