Full Version: Xbmc crashes when playing HD (1080)
Hi! I need help please...
I have installed beta 3 on ubuntu oneiric. It's crashes when I try to play a hd 1080 video. The same video works fine on mplayer and with other player on my ubuntu!
Sanacore
PS
This is the xbmc log generates after crashing:
21:33:25 T:140488622016256 NOTICE: [MovieSets-2.0.4] XBMC (11.0-BETA3 Git:Unknown), Built on Feb 7 2012
21:33:25 T:140488622016256 NOTICE: [MovieSets-2.0.4] Python 2.7.2+ (default, Oct 4 2011, 20:41:12)
[GCC 4.6.1] on linux2
21:33:25 T:140488622016256 NOTICE: -->Python Interpreter Initialized<--
21:33:25 T:140488622016256 NOTICE: [MovieSets] Yes, json use speedup Smile
21:33:25 T:140488622016256 NOTICE: [MovieSets-2.0.4] initialized took 0.019s
21:33:25 T:140488622016256 NOTICE: [MovieSets-2.0.4] InfoScanner: Finished scan. Scanning for moviesets info took 0.005s
21:33:25 T:140488622016256 NOTICE: [MovieSets-2.0.4] MyVideos58.db: last modification is 2012-01-25 20:02:24
21:33:45 T:140489266816896 NOTICE: DVDPlayer: Opening: /media/share/Films/Ink/Ink.2009.1080p.AC3.Badkokos.mkv
21:33:45 T:140489266816896 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:33:45 T:140488598484736 NOTICE: Creating InputStream
21:33:45 T:140488598484736 NOTICE: Creating Demuxer
21:33:45 T:140488598484736 NOTICE: Opening video stream: 0 source: 256
21:33:45 T:140488598484736 NOTICE: Creating video codec with codec id: 28
21:33:45 T:140488598484736 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1080, 28)
21:33:45 T:140488598484736 NOTICE: vdp_device = 0xffffffff vdp_st = 0x00000001
21:33:45 T:140488598484736 ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1. Falling back.
21:33:45 T:140488598484736 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
21:33:45 T:140488598484736 NOTICE: (VDPAU) Close
21:33:45 T:140488598484736 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:33:45 T:140488598484736 NOTICE: Creating video thread
21:33:45 T:140488598484736 NOTICE: Opening audio stream: 1 source: 256
21:33:45 T:140488598484736 NOTICE: Finding audio codec for: 86019
21:33:45 T:140488464721664 NOTICE: running thread: video_thread
21:33:45 T:140488598484736 NOTICE: Creating audio thread
21:33:45 T:140488598484736 NOTICE: Opening Subtitle stream: 2 source: 256
21:33:45 T:140488456328960 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
21:33:45 T:140488456328960 NOTICE: Creating audio device with codec id: 86019, channels: 2, sample rate: 48000, no pass-through
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Please post full log.
The log is too long, I send the first part:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Mon Feb 13 23:11:55 CET 2012
XBMC Options:
Arch: x86_64
Kernel: Linux 3.0.0-15-generic #26-Ubuntu SMP Fri Jan 20 17:23:00 UTC 2012
Release:
Distributor ID: Ubuntu
Description: Ubuntu 11.10
Release: 11.10
Codename: oneiric
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/ted/core (2012-02-13 23:11:55.801106895 +0100)
[New LWP 2185]
[New LWP 2189]
[New LWP 2188]
[New LWP 2206]
[New LWP 2165]
[New LWP 2195]
[New LWP 2190]
[New LWP 2207]
[New LWP 2191]
[New LWP 2193]
[New LWP 2208]
[New LWP 2209]
[New LWP 2194]
[New LWP 2205]
[New LWP 2180]
[New LWP 2183]
[New LWP 2210]
[New LWP 2201]
[New LWP 2197]
[New LWP 2196]
[New LWP 2187]
[New LWP 2204]
[Thread debugging using libthread_db enabled]
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 6, Aborted.
#0 0x00007fc732c0c3a5 in raise () from /lib/x86_64-linux-gnu/libc.so.6
Thread 22 (Thread 0x7fc722868700 (LWP 2204)):
#0 0x00007fc736bfc0dd in read () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x000000000064f97a in ReadFile(CXHandle*, void*, unsigned int, unsigned int*, void*) ()
#2 0x0000000000b08d4e in XFILE::CFileHD::Read(void*, long) ()
#3 0x0000000000afa6e6 in XFILE::CFile::Read(void*, long) ()
#4 0x0000000000939168 in CDVDInputStreamFile::Read(unsigned char*, int) ()
#5 0x00007fc71197f5c8 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#6 0x00007fc71197f7c5 in get_buffer () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#7 0x00007fc711992dda in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#8 0x00007fc711992d45 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#9 0x00007fc711992ffd in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#10 0x00007fc711994bbc in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#11 0x00007fc711995eb0 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#12 0x00007fc7119d2afa in av_read_packet () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#13 0x00007fc7119d3645 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avformat-52-x86_64-linux.so
#14 0x000000000092e75c in CDVDDemuxFFmpeg::Read() ()
#15 0x00000000008f1b96 in CDVDPlayer::ReadPacket(DemuxPacket*&, CDemuxStream*&) ()
#16 0x00000000008f3e74 in CDVDPlayer:Tonguerocess() ()
#17 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
#18 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#19 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#20 0x0000000000000000 in ?? ()
Thread 21 (Thread 0x7fc722067700 (LWP 2187)):
#0 0x00007fc732cb0913 in select () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007fc73385f4bd in ?? () from /usr/lib/libpython2.7.so.1.0
#2 0x00007fc73380f6f5 in PyEval_EvalFrameEx () from /usr/lib/libpython2.7.so.1.0
#3 0x00007fc733810064 in PyEval_EvalFrameEx () from /usr/lib/libpython2.7.so.1.0
#4 0x00007fc733810f05 in PyEval_EvalCodeEx () from /usr/lib/libpython2.7.so.1.0
#5 0x00007fc733811042 in PyEval_EvalCode () from /usr/lib/libpython2.7.so.1.0
#6 0x00007fc733833720 in PyRun_FileExFlags () from /usr/lib/libpython2.7.so.1.0
#7 0x0000000000c4d7b0 in XBPyThread:Tonguerocess() ()
#8 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
#9 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#10 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#11 0x0000000000000000 in ?? ()
Thread 20 (Thread 0x7fc718ff9700 (LWP 2196)):
#0 0x00007fc736bf93cb in [email protected]@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x00000000006daa85 in CJobManager::GetNextJob(CJobWorker const*) ()
#2 0x00000000006dab7a in CJobWorker:Tonguerocess() ()
#3 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
#4 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#5 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#6 0x0000000000000000 in ?? ()
Thread 19 (Thread 0x7fc713fff700 (LWP 2197)):
#0 0x00007fc736bf904c in [email protected]@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x0000000000d9b16c in XbmcThreads::CEventGroup::wait(unsigned int) ()
#2 0x0000000000d2ca66 in CScrobbler:Tonguerocess() ()
Thread 18 (Thread 0x7fc71affd700 (LWP 2201)):
Thread 17 (Thread 0x7fc70eb27700 (LWP 2210)):
#0 0x0000000000a38bd0 in CAudioRendererFactory::Create(IAudioCallback*, int, PCMChannels*, unsigned int, unsigned int, bool, bool, IAudioRenderer::EEncoded) ()
#1 0x00000000008de9e8 in CDVDAudio::Create(stDVDAudioFrame const&, CodecID) ()
#2 0x00000000008f8779 in CDVDPlayerAudio:Tonguerocess() ()
Thread 16 (Thread 0x7fc7289a6700 (LWP 2183)):
#1 0x0000000000d9cc56 in CThread::Sleep(unsigned int) ()
#2 0x0000000000d9461c in MEDIA_DETECT::CDetectDVDMedia:Tonguerocess() ()
Thread 15 (Thread 0x7fc72856d700 (LWP 2180)):
#0 0x00007fc732cab773 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x0000000000d34b92 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#2 0x0000000000d34c30 in PERIPHERALS::CPeripheralBusUSB:Tonguerocess() ()
Thread 14 (Thread 0x7fc71132c700 (LWP 2205)):
#1 0x00007fc711e0af12 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-x86_64-linux.so
#2 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#3 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#4 0x0000000000000000 in ?? ()
Thread 13 (Thread 0x7fc719ffb700 (LWP 2194)):
#1 0x000000000066d83e in SOCKETS::CSocketListener::Listen(int) ()
#2 0x00000000006649d6 in EVENTSERVER::CEventServer::Run() ()
#3 0x0000000000664cc8 in EVENTSERVER::CEventServer:Tonguerocess() ()
#4 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
#5 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#6 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#7 0x0000000000000000 in ?? ()
Thread 12 (Thread 0x7fc70f328700 (LWP 2209)):
#0 0x00007fc736bf61f8 in pthread_join () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x00007fc73479691e in SDL_WaitThread () from /usr/lib/libSDL-1.2.so.0
#2 0x00007fc73478e6ba in SDL_AudioQuit () from /usr/lib/libSDL-1.2.so.0
#3 0x00007fc73478db85 in SDL_QuitSubSystem () from /usr/lib/libSDL-1.2.so.0
#4 0x00007fc73478dc2e in SDL_Quit () from /usr/lib/libSDL-1.2.so.0
#5 0x00007fc73478e22f in ?? () from /usr/lib/libSDL-1.2.so.0
#6 <signal handler called>
#7 0x00007fc732cfebef in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#8 0x00007fc73995cd76 in vaInitialize () from /usr/lib/libva.so.1
#9 0x00000000009242a1 in VAAPI::CDecoder::Open(AVCodecContext*, PixelFormat, unsigned int) ()
#10 0x0000000000916d50 in CDVDVideoCodecFFmpeg::GetFormat(AVCodecContext*, PixelFormat const*) ()
#11 0x00007fc711d54ab0 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-x86_64-linux.so
#12 0x00007fc711d57490 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-x86_64-linux.so
#13 0x00007fc711d57b77 in ?? () from /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-x86_64-linux.so
#14 0x00007fc711e673bc in avcodec_decode_video2 () from /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-x86_64-linux.so
#15 0x0000000000919bd0 in CDVDVideoCodecFFmpeg:Big Grinecode(unsigned char*, int, double, double) ()
#16 0x00000000008fef64 in CDVDPlayerVideo:Tonguerocess() ()
Thread 11 (Thread 0x7fc70fb29700 (LWP 2208)):
Thread 10 (Thread 0x7fc71a7fc700 (LWP 2193)):
#1 0x00007fc7388e5029 in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#2 0x00007fc7388e4b71 in avahi_simple_poll_run () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#3 0x00007fc7388e4dd2 in avahi_simple_poll_iterate () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#4 0x00007fc7388e4f73 in avahi_simple_poll_loop () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#5 0x00007fc7388e50a1 in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#6 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#7 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#8 0x0000000000000000 in ?? ()
Thread 9 (Thread 0x7fc71b7fe700 (LWP 2191)):
#1 0x00007fc73848ff72 in ?? () from /usr/lib/libmicrohttpd.so.5
#2 0x00007fc738490223 in ?? () from /usr/lib/libmicrohttpd.so.5
#3 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#4 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#5 0x0000000000000000 in ?? ()
Thread 8 (Thread 0x7fc71032a700 (LWP 2207)):
Thread 7 (Thread 0x7fc71bfff700 (LWP 2190)):
Thread 6 (Thread 0x7fc7197fa700 (LWP 2195)):
#1 0x000000000066ef79 in JSONRPC::CTCPServer:Tonguerocess() ()
#2 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
Thread 5 (Thread 0x7fc739d5d780 (LWP 2165)):
#0 0x000000000086c37f in CGUIInfoLabel::GetLabel(int, bool) const ()
#1 0x00000000008834c5 in CGUIMultiImage::UpdateInfo(CGUIListItem const*) ()
#2 0x00000000008854db in CGUIMultiImage::UpdateVisibility(CGUIListItem const*) ()
#3 0x0000000000846039 in CGUIControlGroup:Tonguerocess(unsigned int, std::vector<CDirtyRegion, std::allocator<CDirtyRegion> >&) ()
#4 0x000000000083beaf in CGUIControl:Big GrinoProcess(unsigned int, std::vector<CDirtyRegion, std::allocator<CDirtyRegion> >&) ()
#5 0x00000000008ba944 in CGUIWindow:Big GrinoProcess(unsigned int, std::vector<CDirtyRegion, std::allocator<CDirtyRegion> >&) ()
#6 0x00000000008bc950 in CGUIWindowManager:Tonguerocess(unsigned int) ()
#7 0x0000000000de4d27 in CApplication::FrameMove(bool) ()
#8 0x0000000000e65c3e in CXBApplicationEx::Run() ()
#9 0x000000000062fbf0 in main ()
Thread 4 (Thread 0x7fc710b2b700 (LWP 2206)):
Thread 3 (Thread 0x7fc721866700 (LWP 2188)):
#4 0x00007fc733810064 in PyEval_EvalFrameEx () from /usr/lib/libpython2.7.so.1.0
#5 0x00007fc733810f05 in PyEval_EvalCodeEx () from /usr/lib/libpython2.7.so.1.0
#6 0x00007fc733811042 in PyEval_EvalCode () from /usr/lib/libpython2.7.so.1.0
#7 0x00007fc733833720 in PyRun_FileExFlags () from /usr/lib/libpython2.7.so.1.0
#8 0x0000000000c4d7b0 in XBPyThread:Tonguerocess() ()
#9 0x0000000000d9c8c0 in CThread:ConfusedtaticThread(void*) ()
#10 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#11 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#12 0x0000000000000000 in ?? ()
Thread 2 (Thread 0x7fc721064700 (LWP 2189)):
Thread 1 (Thread 0x7fc723069700 (LWP 2185)):
#1 0x00007fc732c0fb0b in abort () from /lib/x86_64-linux-gnu/libc.so.6
#2 0x00007fc7386bf450 in pa_stream_writable_size () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#3 0x00007fc7347bc35d in ?? () from /usr/lib/libSDL-1.2.so.0
#4 0x00007fc73478e4a3 in ?? () from /usr/lib/libSDL-1.2.so.0
#5 0x00007fc734796705 in ?? () from /usr/lib/libSDL-1.2.so.0
#6 0x00007fc7347da3e9 in ?? () from /usr/lib/libSDL-1.2.so.0
#7 0x00007fc736bf4efc in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#8 0x00007fc732cb789d in clone () from /lib/x86_64-linux-gnu/libc.so.6
#9 0x0000000000000000 in ?? ()
############# END STACK TRACE ###############
################# LOG FILE ##################
23:11:38 T:140493645535104 NOTICE: -----------------------------------------------------------------------
23:11:38 T:140493645535104 NOTICE: Starting XBMC (11.0-BETA3 Git:Unknown), Platform: Linux (Ubuntu 11.10, 3.0.0-15-generic x86_64). Built on Feb 7 2012
23:11:38 T:140493645535104 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:11:38 T:140493645535104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
23:11:38 T:140493645535104 NOTICE: special://masterprofile/ is mapped to: /home/ted/.xbmc/userdata
23:11:38 T:140493645535104 NOTICE: special://home/ is mapped to: /home/ted/.xbmc
23:11:38 T:140493645535104 NOTICE: special://temp/ is mapped to: /home/ted/.xbmc/temp
23:11:38 T:140493645535104 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
23:11:38 T:140493645535104 NOTICE: Local hostname: Home-htpc
23:11:38 T:140493645535104 NOTICE: Log File is located: /home/ted/.xbmc/temp/xbmc.log
23:11:38 T:140493645535104 NOTICE: Setup SDL
23:11:38 T:140493645535104 NOTICE: load settings...
23:11:38 T:140493645535104 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
23:11:38 T:140493645535104 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:11:38 T:140493645535104 NOTICE: loading special://masterprofile/guisettings.xml
23:11:38 T:140493645535104 NOTICE: Getting hardware information now...
23:11:38 T:140493645535104 NOTICE: Checking resolution 11
23:11:38 T:140493645535104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:11:38 T:140493645535104 NOTICE: Loaded playercorefactory configuration
23:11:38 T:140493645535104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:11:38 T:140493645535104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:11:38 T:140493645535104 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:11:38 T:140493645535104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
23:11:38 T:140493645535104 NOTICE: Default DVD Player: dvdplayer
23:11:38 T:140493645535104 NOTICE: Default Video Player: dvdplayer
23:11:38 T:140493645535104 NOTICE: Default Audio Player: paplayer
23:11:38 T:140493645535104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:11:38 T:140493645535104 NOTICE: Log level changed to 0
23:11:38 T:140493645535104 NOTICE: Loading media sources from special://masterprofile/sources.xml
23:11:39 T:140493645535104 NOTICE: Using visual 0x51
23:11:39 T:140493645535104 NOTICE: GL_VENDOR = ATI Technologies Inc.
23:11:39 T:140493645535104 NOTICE: GL_RENDERER = ATI Radeon HD 5700 Series
23:11:39 T:140493645535104 NOTICE: GL_VERSION = 4.1.11005 Compatibility Profile Context
23:11:39 T:140493645535104 NOTICE: GL_SHADING_LANGUAGE_VERSION = 4.10
and now the last part... thanks!
3:11:39 T:140493645535104 NOTICE: GL_EXTENSIONS = GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trace GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_vertex_shader_tessellator GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
23:11:40 T:140493645535104 NOTICE: UDisks: Added /media/share
23:11:40 T:140493645535104 NOTICE: start dvd mediatype detection
23:11:40 T:140493645535104 NOTICE: initializing playlistplayer
23:11:40 T:140493645535104 NOTICE: DONE initializing playlistplayer
23:11:40 T:140493645535104 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
23:11:40 T:140493645535104 ERROR: Previous line repeats 1 times.
23:11:40 T:140493645535104 NOTICE: initialize done
23:11:40 T:140493645535104 NOTICE: Running the application...
23:11:40 T:140493246068480 NOTICE: -->Python Interpreter Initialized<--
23:11:40 T:140493254461184 NOTICE: -->Python Interpreter Initialized<--
23:11:40 T:140493237675776 NOTICE: -->Python Interpreter Initialized<--
23:11:40 T:140493645535104 NOTICE: Webserver: Starting...
23:11:40 T:140493645535104 NOTICE: WebServer: Started the webserver
23:11:40 T:140493645535104 NOTICE: ES: Starting event server
23:11:40 T:140493111408384 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
23:11:40 T:140493111408384 NOTICE: UDP: Listening on port 9777
23:11:40 T:140493645535104 NOTICE: starting zeroconf publishing
23:11:40 T:140493645535104 ERROR: GLX: Same window as before, refreshing context
23:11:41 T:140493237675776 ERROR: Previous line repeats 1 times.
23:11:41 T:140493237675776 NOTICE: StorageServer Module loaded RUN
23:11:41 T:140493237675776 NOTICE: StorageClient-0.9.1 Starting server
23:11:41 T:140493128193792 NOTICE: -->Python Interpreter Initialized<--
23:11:41 T:140493254461184 NOTICE: Artwork Downloader: ## Service - Run at startup: False
23:11:41 T:140493254461184 NOTICE: Artwork Downloader: ## Service - Delayed startup: -- minutes
23:11:41 T:140493254461184 NOTICE: Artwork Downloader: ## Service - Run as service: False
23:11:41 T:140493254461184 NOTICE: Artwork Downloader: ## Service - Time: 00:00
23:11:42 T:140493229278976 ERROR: ADDON: extension '' is not currently supported for service addon
23:11:44 T:140493229278976 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
23:11:55 T:140493645535104 ERROR: Previous line repeats 13 times.
23:11:55 T:140493645535104 NOTICE: DVDPlayer: Opening: /media/share/Films/Ink/Ink.2009.1080p.AC3.Badkokos.mkv
23:11:55 T:140493645535104 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
23:11:55 T:140493254461184 NOTICE: Creating InputStream
23:11:55 T:140493254461184 NOTICE: Creating Demuxer
23:11:55 T:140493254461184 NOTICE: Opening video stream: 0 source: 256
23:11:55 T:140493254461184 NOTICE: Creating video codec with codec id: 28
23:11:55 T:140493254461184 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1080, 28)
23:11:55 T:140493254461184 NOTICE: vdp_device = 0xffffffff vdp_st = 0x00000001
23:11:55 T:140493254461184 ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1. Falling back.
23:11:55 T:140493254461184 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
23:11:55 T:140493254461184 NOTICE: (VDPAU) Close
23:11:55 T:140493254461184 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:11:55 T:140493254461184 NOTICE: Creating video thread
23:11:55 T:140493254461184 NOTICE: Opening audio stream: 1 source: 256
23:11:55 T:140493254461184 NOTICE: Finding audio codec for: 86019
23:11:55 T:140492930189056 NOTICE: running thread: video_thread
23:11:55 T:140493254461184 NOTICE: Creating audio thread
23:11:55 T:140493254461184 NOTICE: Opening Subtitle stream: 2 source: 256
23:11:55 T:140492921796352 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
23:11:55 T:140492921796352 NOTICE: Creating audio device with codec id: 86019, channels: 2, sample rate: 48000, no pass-through
Please enable debugging in system settings. btw: there are better ways to post logs.
Hi FernetMenta!
how I can send the log file?
thanks!
sanacore Wrote:Hi FernetMenta!
thanks!
http://pastebin.com/ Post log there, post link here.
The title is "crash when playing HD", does SD work?
Can you duplicate this issue with skin confluence?
What happens if you switch off hardware acceleration? Have you installed xvba backend driver for vaapi properly?
- It works fine with SD.
- I use just confluence skin.
- I tested to switch off hardware acceleration VDPAU and now it works!
- I don't know if xvba backend driver is installed, how can find it?
Hi, all
I have the same problem. I recently upgraded from Ubuntu 9 to Linux Mint 12 (Ubuntu 11), in part because of Mint's reputation for being multimedia-friendly. After installing Mint, I downloaded the latest ATI drivers for my Acer laptop. I also downloaded XBMC "Eden", which was working very nicely on my previous Ubuntu set-up. Unfortunately, the combination of Ubuntu Oneiric/Mint 12, the latest Catalyst driver and XBMC "Eden" doesn't seem to get along very well, at least for HD/Blu-ray playback. Everything seems to work well for SD videos, but trying to play a h264 file results in an immediate crash. (And I do mean immediate -- the file doesn't even seem to load.) I'd post a crash log, but they look exactly like the one posted above. I should also note that VLC and MPlayer can play h264 files on the same set-up. Unfortunately, while the basic picture quality is very good, there's quite a bit of stutter on playback. Any suggestions on how to remedy the problem would be appreciated. :confused2:
