Full Version: Cant seem to get my calibration dialed in
The weird thing is that it was working fine a while back. Just noticed it was off a few days ago.
I'm running XBMC as a dual monitor out of my main pc through an HDMI cable. It works fine, plays smooth and all that, I just have one small bug I cant work out.
My XBMC UI looks great, and I'm pretty sure my videos are playing at the correct resolution but when I use the on screen menus during playback, they are off.
Picture:
As you can see, the left, right, top, and bottom are all getting chopped a little.
I have checked my calibration and it seems correct, like I said, in the main menus everything seems lined up well. Its just in video playback that the menus are off.
Any ideas?
check your video card control panel. in ati this is fixed by setting it to underscan a bit
As I recall the Catalyst Control Center keeps settings separately for each refresh rate. If you have XBMC set to adjust the refresh rate to match the video that means the card is using different settings when the video is playing.
JR
