Full Version: Xmbc on Win 7 : problem
I'm in trouble with xbmc in normal mode (portable -p command seems fine)
In normal mode no add on is working so i'd need your assitance to fix that
Thank you
Here is the log (not full only the relevant data)
15:58:39 T:4640 NOTICE: load settings...
15:58:39 T:4640 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:58:39 T:4640 NOTICE: loading special://masterprofile/guisettings.xml
15:58:39 T:4640 NOTICE: Getting hardware information now...
15:58:39 T:4640 NOTICE: Checking resolution 11
15:58:39 T:4640 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:58:39 T:4640 NOTICE: Loaded playercorefactory configuration
15:58:39 T:4640 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:58:39 T:4640 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:58:39 T:4640 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:58:39 T:4640 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:58:39 T:4640 NOTICE: Default DVD Player: dvdplayer
15:58:39 T:4640 NOTICE: Default Video Player: dvdplayer
15:58:39 T:4640 NOTICE: Default Audio Player: paplayer
15:58:39 T:4640 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:58:39 T:4640 NOTICE: Log level changed to 0
15:58:39 T:4640 NOTICE: Loading media sources from special://masterprofile/sources.xml
15:58:40 T:4640 NOTICE: initializing playlistplayer
15:58:40 T:4640 NOTICE: DONE initializing playlistplayer
15:58:41 T:4236 ERROR: CRemoteControl::Connect - failed to connect
15:58:42 T:4640 NOTICE: initialize done
15:58:42 T:4640 NOTICE: Running the application...
15:58:42 T:4640 NOTICE: ES: Starting event server
15:58:42 T:2352 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:58:42 T:2352 NOTICE: UDP: Listening on port 9777
15:58:42 T:5100 ERROR: JSONRPC Server: Select failed
15:58:42 T:1496 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 7
15:58:42 T:1496 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
15:58:42 T:4304 NOTICE: -->Python Interpreter Initialized<--
15:58:42 T:3300 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 7
15:58:42 T:3300 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/eden-pre/addons.xml.md5>
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/eden-pre/addons.xml|Encoding=gzip>
15:58:42 T:3300 ERROR: Repository XBMC.org Add-ons returned no add-ons, listing may have failed
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://xbmc-adult.googlecode.com/svn/trunk/addons.xml.md5>
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://xbmc-adult.googlecode.com/svn/trunk/addons.xml>
15:58:42 T:3300 ERROR: Repository XBMC-Adult Addons returned no add-ons, listing may have failed
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://bluecop-xbmc-repo.googlecode.com/svn/trunk/addons.xml.md5>
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://bluecop-xbmc-repo.googlecode.com/svn/trunk/addons.xml>
15:58:42 T:3300 ERROR: Repository bluecop Add-on Repository returned no add-ons, listing may have failed
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://passion-xbmc.org/addons/addons.xml.md5>
15:58:42 T:3300 ERROR: XFILE::CFileCache::Open - failed to open source <http://passion-xbmc.org/addons/addons.php|Encoding=gzip>
15:58:42 T:3300 ERROR: Repository Passion-XBMC.org Add-ons returned no add-ons, listing may have failed
15:58:43 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:43 T:5100 ERROR: JSONRPC Server: Select failed
15:58:44 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:44 T:5100 ERROR: JSONRPC Server: Select failed
15:58:45 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:45 T:5100 ERROR: JSONRPC Server: Select failed
15:58:46 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:46 T:5100 ERROR: JSONRPC Server: Select failed
15:58:47 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:47 T:5100 ERROR: JSONRPC Server: Select failed
15:58:48 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:48 T:5100 ERROR: JSONRPC Server: Select failed
15:58:49 T:5100 ERROR: JSONRPC Server: Failed to bind serversocket
15:58:49 T:5100 ERROR: JSONRPC Server: Select failed
Please don't post logs in the forum. Copy and paste the full log, not an extract to http://pastebin.com/ and post the link here. Remember to enable debug logging from System settings, System, Debugging and restart XBMC before recording the log.
Your log is full of Curl error 7 messages. This is CURLE_COULDNT_CONNECT and means Curl couldn't connect to the host. Have you accidentally enabled the proxy settings in System settings, Network?
JR
The proxy settings are disabled i have checked
Debug log?
JR
Full log: http://pastebin.com/hQjtYG1w
Thanks for your help
It's definitely a network problem. Normally I'd suspect the network setup on your PC, but if XBMC runs in portable mode it can't be that.
Try restting all the settings to the defaults. To do this press Windows-R and in the Run dialog type:
"%appdata%\xbmc\userdata"
(including the quotes) and click Ok and an Explorer window should open. In this window find a file called guisettings.xml and delete or rename it. When you start XBMC it will start with default settings.
JR
I tried your suggestion jhsrennie but no effect
Could it be because i have installed xbmc on Program Files (x86) which is a different path than 32 bits version of windows 7/vista which is usually only "Program Files"
themaster1 Wrote:Could it be because i have installed xbmc on Program Files (x86) which is a different path than 32 bits version of windows 7/vista which is usually only "Program Files"
No, on x64 Windows XBMC will install into "Program Files (x86)" and this is a perfectly good location for it, though you can install XBMC to anywhere you want and it should still work fine.
Can you post a debug log for XBMC running in portable mode. That will give us something to compare the failing log with.
You could try deleting or renaming the whole XBMC folder from %APPDATA%.
JR
Log (Normal mode):
http://pastebin.com/bELcuyG3
Portable mode (-p):
http://pastebin.com/XvKHHqiX
These 2 logs reflect the following actions:
I tried to play a video with the add on Canal+.
In portable mode is worked just fine (strangely enough (for me) at the end of the log we can see "Failed to bind serversocket" i'm not sure why is that)
In normal mode i don't even have the video list displayed, so nothing happens
I could take all the add ons i have installed the results would be the same.
Finally i found out. It was because of the software profixier. Disabling the proxy option wasn't enough so i had to uninstall it. I'm not sure why because it's working fine on Xp so it's probably an incompatibility .
Everything's working now
