Is there an addon or does the team plan on adding a way to access and view movies from my Netflix account?
XBMCFlicks is the Netflix plug in, you will need to be running Windows or OSX to use it.
Thanks! I did a search and looked in addons on the XBMC machine and didn't see it. I'll look again...
well, that is to say, XBMCFlix gives you an in-XBMC GUI for selecting movies, then launches a browser for actual playback. Not a bad solution, though.
Ned Scott Wrote:well, that is to say, XBMCFlix gives you an in-XBMC GUI for selecting movies, then launches a browser for actual playback. Not a bad solution, though.
So do you see a window or is it just shown transparently in XBMC? I'm just wondering if my remote will still work for play pause, etc.
