Full Version: XBMC Wakes up my PC
Hi!
I'm a new XBMC user, installed it on last weekend, and I'm really satisfied with it, except for one thing: it always wakes up my pc.
I usually just put my PC to sleep instead of turning it off. Since I have XBMC, I usually activate sleep mode directly from the exit menu of XBMC, but since then, when I arrive home after work, I always find my machine turned on.
As nothing else changed, except for the XBMC, I suspect that it could be the one who wakes up the machine.
According to the Event Logger, every wake up occured between 4:45 PM and 5:00 PM
Is there an option to switch back on, or what could cause this?
I use the latest stable version of XBMC (10.1), and Windows 7 x64 SP1
Thanks for your help
It's not XBMC.
Ned Scott Wrote:It's not XBMC.
you were right.
after a powercfg -lastwake it turned out that Windows Media Center scheduled something that wakes up the PC.
thank you for your help
ps: is there a way that I can close the thread or mark it as "Solved"?
