Since upgrading to the latest EDEN 3 beta even when browsing videos with the Files tab I still see a library style summary rather than explicit file names. Is there some way I can change this behavior? For instance before in a listing it would be show.2009.S01E01.avi or something and now it shows just Show 2009 even when using the files navigator tab under videos.
Sorry if this is kind of unclear; I can post screenshots if required.
It's already been removed in the main git (i.e. so won't do that to files that aren't in the library in the next Eden build). In the meantime, you can disable the "use library names for files" or some such in Settings->Video->File lists.
Cheers,
Jonathan
jmarshall Wrote:It's already been removed in the main git (i.e. so won't do that to files that aren't in the library in the next Eden build). In the meantime, you can disable the "use library names for files" or some such in Settings->Video->File lists.
Cheers,
Jonathan
Oh, great! Thanks; keep up the good work. I'm just OCD about how all my stuff is organized and named
I'm really liking the new betas though!
