2012-02-16, 05:25
Ok all so I have recently purchased the following remote.
http://wiki.xbmc.org/index.php?title...ion_HDX_Remote
Mine is the latest version with the coloured buttons up the top. I know how to map certain actions to key bindings through the wiki as I have been messing around with it a bit.
However my problem is I am not sure what the actual buttons are called to be able to bind them in the <remote> section. For example I want to bind the green button in the middle, the coloured buttons and the guide / info button.
While I have event ghost running, it often doesn't pick up the remote input properly so instead of issuing a command it waits for me to push it again to get the right command. I want to try with key bindings but no idea where to start, how do you work out when you push a button what signal it is sending to the IR receiver? Cheers!
EventGhost isn't working perfectly so I want to try it without the app in the background, the tutorials I've read are a bit confusing
