Full Version: [Windows XP] Eden 11 Beta 3 working well
Just to note loaded Eden 11.0 Beta 3 on a Windows XP SP3 machine.
I like the layout of the confluence skin. Easy to navigate especially "Play Disk" at same "level as "Play File". maybe it was there in XBMC 10. 0 but previously I always had to navigate to bottom LH corner of main screen to start a DVD.
Playing of video and audio files is fine. I like the default (?) positioning of the controls at the bottom of the screen rather than the top (maybe a skin option?).
Hanging problem with iplayer v2 plugin (current version). Reported on Google code (if that is the correct place)
I am using the Android XBMC remote control (0.8.8 beta 1) on my Galaxy Ace mobile phone and that works well with Eden Beta 3 i.e. responsive, easy to navigate and no hangs.
