Hello,
i'am using xbmcbuntu with de default skin.
In this skin there is some white lines (along the central menu bar for exemple).
I have an old plasma TV (50-60Hz), and from visual point of view, theses white lines seems blinking (so it 's not very and it is not very pleasant).
Is there a way to change/remove theses lines ? or video settings ?
regards
nunu
If you mean these:
Then you have to delete the image controls with "seperator.png" inside control9000 ---> Home.xml
mm
thanks a lot! but i have forgotten a word : in fact this is horizontal lines that blinks !
I'am taking a look to the home.xml to find the png to remove (if any ..)
regards
nunu Wrote:in fact this is horizontal lines that blinks !
If you can post a screenshot, I can point you to the control ;-)
cheers,
mad-max
in fact in your screenshot, we see horinzontal white line on each side of the horizontal menu bar .
Uploaded with
ImageShack.us
hey nunu,
now I got what you meant...
This is HomeBack.png itself...
You might edit the the gfx itself and remove the white border...
mad-max
oula
I will try !
thanks for your anwsers !!
regards
nunu
MM, What is a good lite/medium (not full blown gfx editing capabilities ) gfx editor would u suggest? could you list a few ? or anyone for that matter
i try to find the .png file put i didn't.
I guess this is in a compressed file or something like that ?
regards
nunu
@cruzannavy:
I only use GIMP for this, because this is for me, as a total GFX noob, easy to handle...
@nunu:
If this is the original Confluence, it's inside textures.xbt...
You might check my github page because in my MOD are uncompressed textures...
mad-max
