Full Version: [windows] Movie Sets Addon
Hello,
I'm getting an error when I try to load the movie sets addon. It says "Fout in script: Manager.PY"
xbmc.log says the following:
18:15:54 T:2588 M:2316587008 INFO: -->Python script returned the following error<--
18:15:54 T:2588 M:2316587008 ERROR: Error Type: exceptions.ImportError
18:15:54 T:2588 M:2316587008 ERROR: Error Contents: No module named xbmcvfs
18:15:54 T:2588 M:2316587008 ERROR: Traceback (most recent call last):
File "C:\Users\haateepeecee\AppData\Roaming\XBMC\addons\script.moviesets\lib\manager.py", line 13, in ?
import xbmcvfs
ImportError: No module named xbmcvfs
18:15:54 T:2588 M:2316587008 INFO: -->End of Python script error report<--
I'm running Dharma 10.1 with the skin Aeon MQ3
bobsh Wrote:Hello,
import xbmcvfs
Movie Sets cannot be used on Dharma10.1
Eden11.0 ONLY
Martijn Wrote:Movie Sets cannot be used on Dharma10.1
Eden11.0 ONLY
Strange, because it has worked before.
Did it have an update, so it doesn't work anymore with 10.1?
bobsh Wrote:Strange, because it has worked before.
Aaah yes there was a Dharma version Smile
You probably somehow got the Eden version installed (through some 3rd party repo)
can't recall where you can get the original Dharma add-on...
I have problems with this addon. Clean instalation of Eden and when I start Movie Sets addon he want from me to create movie set. But I allready have bunch of movie sets. Nevertheless, I create new set but nothing happends Sad
version 2.0.1
EDIT:
new version fixed the problem
