Hey guys, I got this skin set up yesterday but I want to change my library visual in movies but everytime i choose something and I go to check it doesnt work. Iv roamed all over the forums and cant find an answer. does anyone know what the problem might be?
by library visual I mean changing the view type. BTW
I have problem with Library Visual too.
After upgrade Dharma to Eden I see for example "Movies" only in List. Other ViewTypes not working(?)
Have you gone into the MQ3 skin settings and selected the optional Movie/TV Shows/Music etc wall views you need to select the one's you want to use
Ok. When I turn on all available Viewtypes I can use only:
List, Low List, Wall, Large List.
I find solution :
Uninstall XBMC, clean Windows registry of XBMC entry, install again XBMC, add "Skin Aeon MQ 3 - Repository" from
http://www.marcosqui.com.br/downloads_english.html to XBMC and download skin MQ 3 by XBMC.
Now everything works - I've WinXP + 11 Eden beta 3.
(I think problem was upgrade Dharma 10.1 to Eden 11 beta 3).
Hi.
Im having the same problem, i can only view movies and everything as list even though i selected the view i wanted on the skin settings. I have tried uninstall/install and clean the registry and it didnt solve it ( it did solve my problem of not being able to set a folder as tv shows) but not this problem.
Anyone else is having or had this problem? How can i fix it? I wanted to use the 3d wall view
Yeah i also am having the above issues ,also having problem getting 3d content to show up,using eden 11 windows 7 professional.
How did you fix it? Im still having the same problem, can only see the movies in list =/
Hi Guys,
Having the same issue, I have the showcase view activated but only shows in list view.
Also I added my movies to the movies menu and series to the tv shows menu, but they both show up on whichever menu I choose(even though they are saved on different hard drives under different folders).
Does anyone have a proper solution to this problem? I've tried remaking my library... Still only getting a list view with Panel as my select ViewType. Nothing in the above post hints at a fix.
