Part of the log follows:
11:52:54 T:2548 DEBUG: ------ Window Init (DialogProgress.xml) ------
11:52:55 T:2548 DEBUG: ------ Window Init (DialogVideoScan.xml) ------
11:52:55 T:2548 INFO: Loading skin file: DialogVideoScan.xml
11:52:55 T:3412 DEBUG: Thread VIDEO::CVideoInfoScanner start, auto delete: 0
11:52:55 T:3412 NOTICE: VideoInfoScanner: Starting scan ..
11:52:55 T:3412 DEBUG: VideoInfoScanner: Scanning dir '//videobox/video/sd/' as not in the database
11:52:55 T:3412 DEBUG: VideoInfoScanner: No (new) information was found in dir //videobox/video/sd/
11:52:55 T:3412 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
11:52:55 T:3412 INFO: Video scan was stopped or finished ... restoring FindRemoteThumbs
11:52:55 T:3412 DEBUG: Thread VIDEO::CVideoInfoScanner 3412 terminating
11:52:55 T:2548 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
11:52:55 T:2548 DEBUG: ParentPath = [sources://video/]
11:52:55 T:3316 DEBUG: Thread Background Loader start, auto delete: 0
11:52:55 T:3316 DEBUG: Thread Background Loader 3316 terminating
11:52:55 T:2548 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
11:52:55 T:2548 DEBUG: ------ Window Deinit (DialogVideoScan.xml) ------
11:52:58 T:2548 DEBUG: SDLKeyboard: scancode: 2e, sym: 0063, unicode: 0063, modifier: 0
11:52:58 T:2548 DEBUG: CApplication::OnKey: c (f043) pressed, action is ContextMenu
11:52:58 T:2548 DEBUG: CFavourites::Load - no system favourites found, skipping
11:52:58 T:2548 DEBUG: CFavourites::Load - no userdata favourites found, skipping
11:52:58 T:2548 INFO: Loading skin file: DialogContextMenu.xml
11:52:58 T:2548 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
11:52:58 T:2548 DEBUG: ------ Window Deinit (Pointer.xml) ------
11:52:58 T:2548 DEBUG: ------ Window Init (Pointer.xml) ------
11:52:59 T:2548 DEBUG: CApplication:
rocessMouse: trying mouse action leftclick
11:52:59 T:2548 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
11:52:59 T:2548 DEBUG: ------ Window Init (DialogVideoScan.xml) ------
11:52:59 T:2548 INFO: Loading skin file: DialogVideoScan.xml
11:52:59 T:3100 DEBUG: Thread VIDEO::CVideoInfoScanner start, auto delete: 0
11:53:00 T:3100 NOTICE: VideoInfoScanner: Starting scan ..
11:53:00 T:3100 DEBUG: VideoInfoScanner: Scanning dir '//videobox/video/sd/' as not in the database
11:53:00 T:3100 DEBUG: VideoInfoScanner: No (new) information was found in dir //videobox/video/sd/
11:53:00 T:3100 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
11:53:00 T:3100 INFO: Video scan was stopped or finished ... restoring FindRemoteThumbs
11:53:00 T:3100 DEBUG: Thread VIDEO::CVideoInfoScanner 3100 terminating
11:53:00 T:2548 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
11:53:00 T:2548 DEBUG: ParentPath = [sources://video/]
11:53:00 T:2440 DEBUG: Thread Background Loader start, auto delete: 0
11:53:00 T:2440 DEBUG: Thread Background Loader 2440 terminating
11:53:00 T:2548 DEBUG: ------ Window Deinit (DialogVideoScan.xml) ------
11:53:00 T:2548 DEBUG: CApplication:
11:53:00 T:2548 DEBUG: CGUIMediaWindow::GetDirectory (//videobox/video/sd/)
11:53:00 T:2548 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from movieview where c23=5
11:53:00 T:2300 DEBUG: Thread Background Loader start, auto delete: 0
11:53:00 T:2300 DEBUG: Thread Background Loader 2300 terminating
11:53:02 T:2548 DEBUG: SDLKeyboard: scancode: 2e, sym: 0063, unicode: 0063, modifier: 0
11:53:02 T:2548 DEBUG: CApplication::OnKey: c (f043) pressed, action is ContextMenu
11:53:02 T:2548 DEBUG: CFavourites::Load - no system favourites found, skipping
11:53:02 T:2548 DEBUG: CFavourites::Load - no userdata favourites found, skipping
11:53:02 T:2548 INFO: Loading skin file: DialogContextMenu.xml
11:53:02 T:2548 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
11:53:02 T:2548 DEBUG: ------ Window Deinit (Pointer.xml) ------
11:53:02 T:2548 DEBUG: ------ Window Init (Pointer.xml) ------
11:53:03 T:2548 DEBUG: CApplication:
11:53:03 T:2548 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
11:53:03 T:2548 DEBUG: ------ Window Init (DialogVideoScan.xml) ------
11:53:03 T:2548 INFO: Loading skin file: DialogVideoScan.xml
11:53:03 T:4804 DEBUG: Thread VIDEO::CVideoInfoScanner start, auto delete: 0
11:53:03 T:4804 NOTICE: VideoInfoScanner: Starting scan ..
11:53:03 T:4804 DEBUG: VideoInfoScanner: Scanning dir '//videobox/video/sd/' as not in the database
11:53:03 T:4804 DEBUG: VideoInfoScanner: No (new) information was found in dir //videobox/video/sd/
11:53:03 T:4804 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
11:53:03 T:4804 INFO: Video scan was stopped or finished ... restoring FindRemoteThumbs
11:53:03 T:4804 DEBUG: Thread VIDEO::CVideoInfoScanner 4804 terminating
11:53:04 T:2548 DEBUG: CGUIMediaWindow::GetDirectory (//videobox/video/sd/)
11:53:04 T:2548 DEBUG: ParentPath = [//videobox/video/sd/]
11:53:04 T:2548 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from movieview where c23=5
11:53:04 T:2660 DEBUG: Thread Background Loader start, auto delete: 0
11:53:04 T:2660 DEBUG: Thread Background Loader 2660 terminating
11:53:04 T:2548 DEBUG: ------ Window Deinit (DialogVideoScan.xml) ------
11:53:07 T:2548 DEBUG: CApplication:
11:53:07 T:2548 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
11:53:07 T:2548 DEBUG: ParentPath = []
11:53:07 T:4212 DEBUG: Thread Background Loader start, auto delete: 0
11:53:07 T:4212 DEBUG: Thread Background Loader 4212 terminating
11:53:09 T:2548 DEBUG: SDLKeyboard: scancode: 01, sym: 001b, unicode: 001b, modifier: 0
11:53:09 T:2548 DEBUG: CApplication::OnKey: escape (f01b) pressed, action is PreviousMenu
11:53:09 T:2548 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
11:53:09 T:2548 DEBUG: ------ Window Deinit (Pointer.xml) ------
11:53:09 T:2548 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
reviousWindow: Activate new
11:53:09 T:2548 DEBUG: ------ Window Init (Home.xml) ------
11:53:09 T:2548 INFO: Loading skin file: Home.xml
11:53:09 T:2548 DEBUG: ------ Window Init (Pointer.xml) ------
11:53:12 T:2548 DEBUG: CApplication:
11:53:12 T:2548 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(Settings)
11:53:12 T:2548 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(Settings)
11:53:12 T:2548 DEBUG: Activating window ID: 10004
11:53:12 T:2548 DEBUG: ------ Window Deinit (Home.xml) ------
11:53:12 T:2548 DEBUG: ------ Window Init (Settings.xml) ------
11:53:12 T:2548 INFO: Loading skin file: Settings.xml
11:53:16 T:2548 DEBUG: CApplication:
11:53:16 T:2548 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(SystemSettings)
11:53:16 T:2548 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(SystemSettings)
11:53:16 T:2548 DEBUG: Activating window ID: 10016
11:53:16 T:2548 DEBUG: ------ Window Deinit (Settings.xml) ------
11:53:16 T:2548 DEBUG: ------ Window Init (SettingsCategory.xml) ------
11:53:16 T:2548 INFO: Loading skin file: SettingsCategory.xml
11:53:17 T:2548 DEBUG: CApplication:
11:53:18 T:2548 DEBUG: Previous line repeats 1 times.
11:53:18 T:2548 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:53:18 T:2548 NOTICE: Log level changed to 0
11:53:24 T:2548 NOTICE: Storing total System Uptime
11:53:24 T:2548 NOTICE: Saving settings
11:53:24 T:2548 NOTICE: stop all
11:53:24 T:2548 NOTICE: ES: Stopping event server
11:53:24 T:2548 NOTICE: stopping zeroconf publishing
11:53:25 T:2540 NOTICE: ES: UDP Event server stopped
11:53:25 T:2548 NOTICE: stop sap announcement listener
11:53:25 T:2548 NOTICE: clean cached files!
11:53:25 T:2548 NOTICE: unload skin
11:53:25 T:2548 ERROR: ADDON: extension 'downloader\' is not currently supported for service addon
11:53:25 T:2548 NOTICE: stop python
11:53:25 T:2548 NOTICE: stopped
11:53:25 T:2548 NOTICE: destroy
11:53:25 T:2548 NOTICE: closing down remote control service
11:53:26 T:2548 NOTICE: unload sections
11:53:26 T:2548 NOTICE: destroy
11:53:26 T:2548 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:53:26 T:2548 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:53:26 T:2548 NOTICE: closing down remote control service
11:53:26 T:2548 NOTICE: application stopped...
