Just updates to Eden beta 3 and all my tv shows in mkv format show subtitles all the time, the files have subtitles in they are set as non default I have tried to turn them off on the video osd settings but it comes up with none.
Does anyone have any idea how to turn them off, well without re-muxing them?
have also done a complete wipe and reinstall and same issue happens, no matter what subtitles are always displayed.
Removed and now link to Pastebin below
Read the link I posted again. It says very specifically what needs to be done, including turning debugging on for the log and to post the log to pastebin and not directly to the forum.
Sorry I did have debugging on but forgot to re do that as I tried a fresh jailbreak and install to see if that helped, which it hasnt.
Pastebin line is here:
http://pastebin.com/phdjmDvh
Log file does not show any video being played
Sorry, think I have sorted it now, the MKV file shows no subtitles as they are part of the file, the only way I could shut these off was to disable subtitles, in the non beta versions I was able to see the subs in the MKV and disable them that way.
Ned, thanks for your help on this and sorry to waste your time.
