Full Version: [LIVE] My Eden XBMCbuntu setup
I always do quite a lot if customization in my live setup as it has to double up as a server.
I just started with XBMCbuntu beta3 and this is how far I am so far:
Fix overscan in xbmc
/system/system/video output/video calibration
Fix overscan in XBMCbuntu session
Find the start menu down left outside the picture and start nvidia-settings
Go to the TV line and set overscan compensation
install stuff
sudo apt-get install lxterminal leafpad file-roller gdebi
Install a "remote desktop" - NX server
Login over ssh
mkdir Downloads
cd Downloads
wget [url]http://64.34.161.181/download/3.5.0/Linux/nxclient_3.5.0-7_i386.deb[/url]
wget [url]http://64.34.161.181/download/3.5.0/Linux/nxnode_3.5.0-7_i386.deb[/url]
wget [url]http://64.34.161.181/download/3.5.0/Linux/FE/nxserver_3.5.0-9_i386.deb[/url]
sudo apt-get install libaudiofile0 && sudo dpkg -i nxclient_3.5.0-7_i386.deb nxnode_3.5.0-7_i386.deb nxserver_3.5.0-9_i386.deb
We may get some errors becuase dpkg can not handela the dependencies we can either do that manually or:
sudo apt-get upgrade -f
Now we can connect from the laptop with nx server client for windows.
Select custom  and enter
/usr/bin/startxbmcbuntu
& new virtual desktop
Alternatively:
(/usr/bin/lxsession -s XBMCbuntu -e LXDE)
or
/usr/bin/startfluxbox
or
/usr/bin/openbox-session
or
/usr/bin/lxsession
Mount the media partition
1)
View partitions:
sudo fdisk -l
Hopefully you can find your unmounted partition. (if not or if you did not create the partition you need to install gparted)
In my case the partition is /dev/sda5
2)
Create a mount point (in this case a folder in the root):
sudo mkdir /storage
3)
Edit the fstab:
sudo cp /etc/fstab /etc/fstab_backup
sudo nano /etc/fstab
Add:
/dev/sda5 /storage ext2 defaults 0 0
ext2 since I remember selecting that when I created the partition.
4)
mount:
sudo mount -a
5) set permissions
sudo chown -R xbmc:xbmc /storage
sudo chmod -R 777 /storage
Create a samba share
sudo apt-get install samba
sudo nano /etc/samba/smb.conf
[xbmc]
path = /home/xbmc
public = yes
guest only = yes
writable = yes
browseable = yes
force user = xbmc
inherit permissions = yes
[storage]
path = /storage
public = yes
guest only = yes
writable = yes
browseable = yes
force user = xbmc
sudo service smbd restart
sudo service nmbd restart
