Full Version: ATV1 Goes to Log In Prompt When Idle Too Long
I finally got my ATV1 running a couple weeks ago. I had to stop playing with it because of other things needing to be done. I just started using it the last few days & I noticed that if it sits with out use it will go to a log in prompt. Is there a setting that I need to adjust so this will not happen? Thew only thing I know to do when this happens is to reboot the ATV. I have checked the settings for power down & power savings to make sure they are not set. Thanks for any help you guys can provide.
