Full Version: [Mac] guide for synology
Hi, I have just downloaded and installed xbmc on a new macbook pro.
I seem to have been able to connect to my synology diskstation, and I see 3 folders which are those that synology creates by default, but cannot see all other folders that I have created.
Do you know of any step by step guide available out there?
Many thanks
Nic
Assodispade Wrote:Hi, I have just downloaded and installed xbmc on a new macbook pro.
Many thanks
Nic
Have you enabled file sharing (smb or afp) on your synology?
Anyway, this is not a XBMC problem. You'll have better luck asking support in synology forum.
Many thanks
Nic
Dude pls search through the forums first. There are plenty of threads about tips with your setup here.
