2012-02-18, 21:55
When I play music in Eden Beta 3, sometimes the audio stutters.
I can't say I ever noticed it in Dharma, but after I upgraded to Beta 2 and Beta 3 of Eden it has started.
I only know for sure that it has happened with flac-files. And it feels a bit random when it happens. BUT, it has happened to the same files, at different points in the file.
Doesn't seem like there is anything in the log.
Could this be an issue with PAPlayer?
Quote:20:39:02 T:1276 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers(musicdb://3/264/3220.flac)
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
20:39:02 T:1276 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
20:39:02 T:1276 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
20:39:02 T:1276 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/paplayer/libFLAC.dll)
20:39:02 T:1276 DEBUG: CFileCache::Open - opening <3/264/3220.flac> using cache
20:39:04 T:2436 DEBUG: Thread XFILE::CFileCache start, auto delete: 0
20:39:04 T:1276 INFO: PAPlayer: Playing musicdb://3/264/3220.flac
20:39:04 T:1276 DEBUG: PAPlayer: Creating new audio renderer
20:39:04 T:1276 DEBUG: CWin32WASAPI::Initialize: endpoint device TX-NR709-3 (NVIDIA High Definition Audio)
20:39:04 T:1276 INFO: CPCMRemap: Configured speaker layout: 5.1
20:39:04 T:1276 INFO: CPCMRemap: I channel map: FL,FR
20:39:04 T:1276 INFO: CPCMRemap: O channel map: FL,FR
20:39:04 T:1276 DEBUG: CPCMRemap: Downmix normalization is enabled
20:39:04 T:1276 DEBUG: CPCMRemap: FL = FL(1.000000*)
20:39:04 T:1276 DEBUG: CPCMRemap: FR = FR(1.000000*)
20:39:04 T:1276 DEBUG: CAudioContext::SetActiveDevice - SetActiveDevice from 1 to 0
20:39:04 T:1276 DEBUG: CAudioContext::RemoveActiveDevice - Removing device 1
20:39:04 T:1276 DEBUG: CWin32WASAPI::Initialize: Packet Size = 1792. Avg Bytes Per Second = 176400.
20:39:04 T:1276 DEBUG: CWin32WASAPI::Initialize - Channels: 2 - SampleRate: 44100 - SampleBit: 16 - Resample false - IsMusic true - IsPassthrough 0 - audioDevice: TX-NR709-3 (NVIDIA High Definition Audio)
20:39:04 T:1468 DEBUG: Thread PAPlayer start, auto delete: 0
20:39:04 T:1468 DEBUG: PAPlayer: Thread started
20:39:04 T:1276 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
20:39:04 T:1276 DEBUG: CGUIInfoManager::SetCurrentSong(musicdb://3/264/3220.flac)
20:39:04 T:1276 DEBUG: Loading additional tag info for file smb://user:pass@host/Music/mymusic/flac 100/Neil Young/Greatest Hits/01-Down By The River.flac
20:39:04 T:1276 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
20:39:04 T:1276 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
20:39:04 T:1276 DEBUG: Building didl for object 'musicdb://3/264/3220.flac'
20:39:04 T:1468 INFO: AudioDecoder: File is queued
20:39:22 T:1276 DEBUG: SDLKeyboard: scancode: 2d, sym: 0078, unicode: 0078, modifier: 0
20:39:22 T:1276 DEBUG: CApplication::OnKey: x (f058) pressed, action is Stop
20:39:22 T:1468 INFO: PAPlayer: End of playback reached
20:39:22 T:1468 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
20:39:22 T:1468 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
20:39:22 T:1468 DEBUG: PAPlayer: Thread end
20:39:22 T:1468 DEBUG: Thread PAPlayer 1468 terminating
20:39:22 T:2436 DEBUG: Thread XFILE::CFileCache 2436 terminating
20:39:22 T:1276 DEBUG: CWin32WASAPI::Deinitialize: Cleaning up
20:39:22 T:1276 DEBUG: CAudioContext::SetActiveDevice - SetActiveDevice from 0 to 2
20:39:22 T:1276 DEBUG: CAudioContext::RemoveActiveDevice - Removing device 0
20:39:22 T:1276 DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: Primary Sound Driver
20:39:22 T:1276 DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: TX-NR709-3 (NVIDIA High Definition Audio)
20:39:22 T:1276 DEBUG: CAudioContext::SetActiveDevice - selecting TX-NR709-3 (NVIDIA High Definition Audio) as output devices
20:39:22 T:1276 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
20:39:22 T:2440 DEBUG: CSaveFileStateJob::DoWork - Saving file state for audio item musicdb://3/264/3220.flac
20:39:30 T:1276 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
