Title says it all, Is there anyway to get netflix and/or pandora working on xbmc eden? I've find information that lead me to believe they work on the non beta version but not much about how to use them with eden?
thanks!
There's a NetFlix add-on that should work in Eden. Also I wrote an article on wiki.xbmc.org describing a diy way to use NetFlix.
JR
Pandora works on Eden. The thread in the forums has a link to the github page where you can download it. I have posted numerous times in that thread on how to install from git. Search my posts there and you will find your answer.
jhsrennie Wrote:There's a NetFlix add-on that should work in Eden. Also I wrote an article on wiki.xbmc.org describing a diy way to use NetFlix.
JR
can you post links? a addon for eden that gets netflix working would be awesome but I haven't been able to find it?
htpc guy Wrote:Pandora works on Eden. The thread in the forums has a link to the github page where you can download it. I have posted numerous times in that thread on how to install from git. Search my posts there and you will find your answer.
thanks!, got it working
