Full Version: Xbmc - Lg st600 - DMC
Not quite sure were to post this, I know that the subject has been discussed before but not in this specific case. If this is posted in the wrong sub-section then please either move or remove it mod.
I have a LG st600 box (basically a DLNA renderer with a poor broken implementation of Plex) that does its job great, as long as I'm using DLNA. I'm also using 8Player on my iPad as a DMC to push media from the server to the box, however I'm missing all the awesome features that XBMC/Plex has. Such as the pretty pretty apps with metadata. Big Grin
So I'm wondering if there is a way to use one of the iPad apps as an DMC.
I basically just want the media playing on the ordinary server to play on my st600 instead. XBMC already supports DLNA so it should be possible right? If not, is it possible to flash a custom XBMC firmware, the software to the box is opensource i think.
Anyhow, thankful for any help.
