2012-02-20, 22:04
This can be very easy one but I simply can't solve it. I'm trying to configure my setup (lirc and Lircmap.xml) and I did the job quite fast but I can't get osd button to work with my Logitech universal remote. Everything else works just the way I wanted. I have checked that irw can read the data when I press the button but XBMC does not open the OSD menu.
Of course I can still use the Android remote control but it's not as fancy as using "real" remote control
The setup is very very simple:
lircd.conf
Lircmap.xml
Can you help me with the problem?
lircd.conf
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.8.6(default) on Mon Feb 20 20:14:17 2012
# contributed by
# brand: harmony
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name harmony
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9009 4479
one 565 1667
zero 565 563
ptrail 575
repeat 9004 2224
pre_data_bits 16
pre_data 0xFF
gap 107889
min_repeat 3
toggle_bit_mask 0x0
begin codes
KEY_STOP 0xA857
KEY_PREVIOUS 0x08F7
KEY_NEXT 0xC837
KEY_PLAY 0xAA55
KEY_REWIND 0xCA35
KEY_FASTFORWARD 0x0AF5
KEY_PAUSE 0x6A95
KEY_MENU 0xFA05
KEY_INFO 0xF807
KEY_EXIT 0xF00F
KEY_UP 0x38C7
KEY_LEFT 0xEA15
KEY_ENTER 0x28D7
KEY_RIGHT 0xE817
KEY_DOWN 0x18E7
KEY_TEXT 0xB847
end codes
end remote
Lircmap.xml
<!-- This file contains the mapping of LIRC keys to XBMC keys used in Keymap.xml -->
<!-- How to add remotes -->
<!-- <remote device="name_Lirc_calls_the_remote"> -->
<!-- For the commands the layout following layout is used -->
<!-- <XBMC_COMMAND>LircButtonName</XBMC_COMMAND> -->
<!-- For a list of XBMC_COMMAND's check out the <remote> sections of keymap.xml -->
<lircmap>
<remote device="harmony">
<altname>harmony</altname>
<altname>devinput</altname>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<up>KEY_UP</up>
<down>KEY_DOWN</down>
<select>KEY_ENTER</select>
<start>KEY_SELECT</start>
<back>KEY_EXIT</back>
<play>KEY_PLAY</play>
<pause>KEY_PAUSE</pause>
<stop>KEY_STOP</stop>
<forward>KEY_FASTFORWARD</forward>
<reverse>KEY_REWIND</reverse>
<title>KEY_MENU</title>
<osd>KEY_TEXT</osd>
<info>KEY_INFO</info>
</remote>
</lircmap>
