Full Version: Permission issues on SMB share (was Streaming MKV issue)
I'm having problems paying Some mkv files, They wont even start to play.
Im using beta 2 on my apple tv 2 Streaming from a xp laptop shared folder.
The files will only play if I remux them using mkv2vob which is a hassel.
Can anyone Point out whats causing the issue??
Heres the media info for one of the mkv files I'm having problems with:
Format : Matroska
Format version : Version 2
File size : 1.48 GiB
Duration : 51mn 47s
Overall bit rate : 4 077 Kbps
Writing application : x264.exe
Writing library : mkv2rls x264-tv version built on 2011. febr. 17
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 51mn 47s
Bit rate : 3 612 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.163
Stream size : 1.31 GiB (89%)
Writing library : x264 core 120 r2164 da19765
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=36 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 51mn 47s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 142 MiB (9%)
Language : English
Default : Yes
Forced : No
xbmc.log needed with debugging turned on.
Memphiz Wrote:xbmc.log needed with debugging turned on.
Sorry yes heres the log: http://pastebin.com/QbpWBTPm
Can anyone advise on my issue playing the mkv files from my above log?
ERROR: CDVDPlayer::OpenInputStream - error opening [smb://PJ-2DAD5F496DD0/TV/Luck/Season 01/Luck - S01E04 - Episode 4.mkv]
your samba shares are borked, fix them.
aka use the ip instead of that freaken pc name
Memphiz Wrote:aka use the ip instead of that freaken pc name
Ok I changed the video source in xbmc to smb://192.168.0.9/TV/ If thats what you meant?
But the mkv files still refuse to play unless i remux them to mpg:confused2:
I'm still having this issue thats really bugging meSad
Can anyone Please Help with it from my New LogHuh with Debugging turned on:
http://pastebin.com/cQ2u6hQk
yep - once again ... get your permissions right on your shared drive.
17:54:46 T:120676352    INFO: FileSmb->Open: Unable to open file : 'smb://192%2e168%2e0%2e9/TV/Luck/Season%2001/Luck%20%2d%20S01E04%20%2d%20Episode%204%2emkv'
                                            unix_err:'d' error : 'Permission denied'
i edited the thread title because it has nothing to do with mkv in reality ...
try a start--run--workgroup---change workgroup name---network ID--select home computer
also with your permissions make sure that "everyone" is enabled
Memphiz Wrote:yep - once again ... get your permissions right on your shared drive.
I set permisions for Everyone to Full Control but its still not giving me permission to play these type of mkv files,
The problem seems to be that the file is located in my shared Tv folder (where I keep all my tv shows) on drive partition D: As it plays fine when its located on c: drive in the normal shared documents- my videos folder
Could what partition the files are located in be the problem?
check the permission on that particular file and all folders above it ... it might not be a permission problem on the share, but on the filesystem itlsef...
Memphiz Wrote:check the permission on that particular file and all folders above it ... it might not be a permission problem on the share, but on the filesystem itlsef...
All fixed now and Yes that was the problem, The files were not inheriting the folders permissions, I had to go into the files advanced permission settings to change this.
Thanks for the help folks Smile
