2012-02-21, 13:21
Hi, there is a new version of VLC player which is able to play bluray discs. Is it possible to apply core of player to XBMC for playing bluray movies?
tomasg Wrote:Hi, there is a new version of VLC player which is able to play bluray discs. Is it possible to apply core of player to XBMC for playing bluray movies?
tomasg Wrote:Hi, there is a new version of VLC player which is able to play bluray discs. Is it possible to apply core of player to XBMC for playing bluray movies?If you would like VLC to be your player, you can setup XBMC to use external player. You still can enjoy the nice front-end of XBMC and quality playback of VLC. Here is the instruction, and you can simply replace other players in the codes with VLC- Working External Player Solution!
bluray Wrote:If you want to play blu-ray disc directly on BD-ROM with XBMC Beta 3 "Play Disc" option, you can download "AnyDVD HD" to decrypt blu-ray disc in the background. You should be able to playback blu-ray disc with XBMC!
bluray Wrote:XBMC Beta3 and AnyDVD HD should allow you to playback blu-ray disc directly on BD-ROM using XBMC "Play Disc" option as shown below:
tomasg Wrote:It works better than I thought, thank you for the tip.It can playback as good as any player, and you don't have to mess around with any settings either. It's time to enjoy the movie then!
