Wanilton
Ok, I've tested your version and works again (indeed, only english data but it is an advance
I have not tsted Black09 but is in my list for weekend
Thank you !
My version isn't updated for Gotham and won't work. But it's on my todo list...
Black... where is the problem ?. In my tests with Gotham final in Bello works fine.
Cheers
Neesus
Hey nessus, would you mind telling me how exactly you use it in Bello?
I can use it directly from the addons menu, but not in the info or actor screen (or anywhere else).
At least I can't see the buttons anymore. (Did I ever see a button in Bello? ... I can't remember)
I am on Gotham final using Bello Nero ( wonderful work, btw! )
Greetz, Unr3aL67
(2014-05-12, 22:54)Unr3aL67 Wrote: [ -> ]Hey nessus, would you mind telling me how exactly you use it in Bello?
Greetz, Unr3aL67
Same hwre ...can anyone enlighten me?
I don't understand how a couple options work. The "Get thumb" and "Get fanart" button functionality seems broken at best. "Get thumb" just flat out doesn't seem to have any effect on anything. It lets me scroll through all the available thumbnails, and selecting one brings up the following options:
But none of those options do anything. "Get more" shows a different screen with all the images available remotely, and you can select one or more or all and hit ok and it ostensibly downloads them, but to where? After exiting the screen, they are nowhere to be found and nothing has changed in the actor info screen.
It's a similar story with the "Get fanart", except initially, there is no fanart showing. Pressing the "Get fanart" button brings up a dialog like the "Get more" option for "Get thumb", and once again allows you choose one or more that get downloaded, asking if you want to overwrite before beginning the download. If one item is chosen and downloaded, it displays that item in the formerly empty upper panel (where thumbnails get displayed), but if more than one is selected, once again, nothing changes.
What is the intended functionality of these buttons? Where is this artwork getting downloaded to?
Thanks for an otherwise awesome program add-on.
I'm running Nox 4.1.9 on Gotham.
Hello,
I have the same problem as Surlias.
But when I turn on the debugging, there is an entry that says that an .tbn file has been copied.
It is the right one, but xbmc isn't using that image.
I'm using aeon nox 4.1.9.9.
Can someone help me/us to solve the problem?
Thank you
(2014-07-15, 13:25)groovyfa Wrote: [ -> ] (2014-03-28, 19:51)warlion Wrote: [ -> ]so im the only one with a working metadata?
https://www.dropbox.com/s/nte27rk6qrf32f...actors.zip
Hi Warlion, how do I install this for GOTHAM 13.1?
Just unzip the file and put it in *\XBMC\addons - should be named "script.metadata.actors".
After reset of XMBC you should see the entry "Extra Infos" when clickin onto an actors picture (in the info-screen).
Cheers,
Snorrt
@anybody: Any updates on foreign languages for the bio? Little bit annoying to only get the english version ...
Thanks Snort, it's showing it's installed. How do I get to view the actor information on streams?
Got it to install in Gotham, so thank you for that. I have recently discovered the Eminence skin and I love it, but it does not seem to work with this addon.
Can someone help me get it working? I'm not too good with code.
Is there a chance to show tv series in the filmographie, too?
