Full Version: [RELEASE] Add-on Metadata Actors - Skin support
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
(2012-08-13, 20:04)wellspokenman Wrote: [ -> ]I know this is one of those gift-horse, mouth kinda things, but I'm gonna do it anyway. I love this addon - very cool, and a long time coming. Sure we'll see it in the official repository before too long. How about couch potato integration though? Time and time again we're sitting down going - who was that guy in...no the guy with the hat and the beard. Oh he was that guy - (uses this addon) oh he was in that movie that we don't have yet? - let's get that. Click.
+1Nod
Hi and thanks for this amazing addon!
Im not sure if its ok to report problems in non stable releases, however, I have some problem with the script using the latest nightly builds. I can access the script, but no info is provided, nor does the thumbnails or fanart get saved to the database. Or at least, the thumbs for a specific actor does not change in the XBMC db after chosing a new thumb via the script and downloaded fanart are not shown.
Anyone else experiance this?
Logg: pastebin
/Marcus
I got this add-on recently, and boy do I love it for looking up actor filmographies. One thing I would love to see it the TV shows they have appeared in as well as movies? Is this possible?
(2012-08-06, 09:31)m0v1em4n Wrote: [ -> ]Hi Guys,
This look like a great add-on.
I am Using Aeon MQ4 on Frodo nightly on a windows 7 setup, will this addon work? and what do I need to install to get it to working.
can any one help
**** update***
Ok managed to get it sorted , great add-on
Could you possibly explain how to get this working with MQ4? I'm stupid.
just install and use
nothing special with mq4
it just works
Hmm, I tried Aeon Nox and it doesn't work for me there either. I am using an older build with HD audio built in. Could that be my problem?
Did you use it from Program menu item ?
Don't know if Aeon Nox have include the features of this addon in it's own menu.
(2012-09-25, 14:47)mikebzh44 Wrote: [ -> ]Did you use it from Program menu item ?
no, if you go into your movie then select info for any movie on the info screen you should see additional buttons next to play, rescan, trailer etc
hope that helps
(2012-09-21, 20:00)macardi Wrote: [ -> ]Hi and thanks for this amazing addon!
Logg: pastebin
/Marcus
Hi I am using Frodo Alpha 5 with no problems
Ah, I figured it out. I was just clicking on the actor image, not clicking on get artist info. Sorry about that!
Works fine fine with Aeon Nox3.5, 3.6 and 4.0
Logg: pastebin
/Marcus
Quote:Hi I am using Frodo Alpha 5 with no problems
Thanks for your input! No dice however, tested with various skins but still the same problem. I guess that something has changed since the Alpha 5 that causing this.
/Marcus
sorry for my english
xbmc nighly do not use the same way for save fanart, Frost Know this problem So wait a little
Great! Thanks for yor answer.
Frost, you can include strings Spanish?
http://www.sendspace.com/file/k4qpt2
thanks
Hi Frostbox
Great idea and addon.
one request though :-) ... would it be possible to run the addon in silent mode, so skinners would be able to retreive info about an actor/director and display it in the skin, instead of having to start the addon gui to retreive info. OR maby add the abbility to "retreive info for all actors/directors".
I was looking at the code myself, to see if i could add a silent mode, but the code is quite comprehensive so i found myself getting nowhere fast :-) .. I would love to help if you could point me to some of the code that need to be altered!
cheers
c_bb
