Full Version: manually edit music\video sources \ XBMC crash on music-->files
Hi all,
My XBMC is crashing when clicking the music-->files button.
This started to happen since i changed my router. and so i'm thinking maybe the path is wrong... ? In what files should i look for the installed path ?
Strange thing however is that the few music i already have added to the library is playing fine though ... ?
I'm running the 22-feb build from Hellfire repro, on xubuntu Oneiric.
Any suggestions \ help will be appriciated Smile
Cheers
kamaradski
Problem solved.
Issue was caused by Rubyripper having a lock on my cd-drive, XBMC couldn't access the drive and crashed instantly.
Still not the way things should be, however easily avoidable by not browsing to your music files while ripping Smile
Cheers,
kamaradski
