2012-02-23, 03:12
I'm using xbmc 11 on a debian system, installed from the debian-multimedia.org repository. I'd like to be able to listen to RFI Monde:
http://stream.rfi.fr/rfimonde/all/rfimonde-64k.mp3
It works without problems with mplayer, but making an strm file with the above address doesn't work in xbmc (and other strm files work). This is what I get in xbmc.log after trying to open the strm file:
01:05:46 T:3015608112 ERROR: PulseAudio: Failed to connect context
01:05:46 T:3015608112 ERROR: PulseAudio: Failed to create context
01:05:46 T:2643762032 ERROR: MP3Codec: Error reading file
01:05:46 T:2643762032 ERROR: CAudioDecoder: Error while decoding 1
A related issue is that, for me, most of the radio stations - including RFI Monde - don't work in the Radio add-on.
EDIT: the output of mplayer contains:
Requested audio codec family [mpg123] (afm=mpg123) not available.
Enable it at compilation.
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
libavcodec version 54.3.100 (internal)
AUDIO: 22050 Hz, 2 ch, floatle, 64.0 kbit/4.54% (ratio: 8000->176400)
Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio)
I have exactly the same problem with, say, Radio France Info
