2012-02-24, 03:48
2012-02-24, 08:05
maxone Wrote:how do i disable subtitles in XBMC Eden B3?
thanks.
while watching, press L so that you get infobox downright "subtitles" disabled. There is also menu while wathicng for that under "M" and audio section.
2012-02-26, 17:25
I'm having an issue with Subtitles in Eden Beta 3 as well. Subtitles in MKV files are loading all the time. I've gone into Settings>Video> and deselected "activate teletext". I've also tried to click the subtitles button on the OSD while the movie is playing, but it says "subtitles none" and doesn't allow me an option to disable the subtitles. I can confirm that the subtitles are not hard-coded, as I can change the font through the settings>video>subtitles screen.
