Full Version: Change myvideonav.xml
Hi
Is the way to display rewritten myvideonav.xml (included on my plugin: Default/720p/MyVideoNav.xml path) instead of original myvideonav.xml on original skin? I'd like to change looks of this window to display on my own plugin.
If yes can you show me examples? If not, can you suggest another method?
Plesken
No. There is no method. The skin has the final word.
