Full Version: Which folder? & LiveTv plug-in
hi XBMC communitySmile,
i was wondering when installing add-ons to the private/var/mobile folder then choose home folder, then from there i have noticed some people use private/var/mobile/Applications...while others use private/var/mobile/media...does this make any difference when adding/removing add-on repositories or tv plug-ins??
Is there really any difference since i couldn't find my answer on online manual cuz it did not state or detail the very last choice of folder to use, Applications or Media??
I installed a LiveTv plug-in yesterday and added LiveTv source path 2 times by accident...so now i have 2 exact same paths or copies of the same url to.xml, is there a way i could delete one of the 2 exact same paths/url from.xml(say fom SYSTEM>File Manager) and if i can, how is it done, since it does not give me an option to delete:confused2:...i would even be ok deleting/clearing both sources from .xml and then re-adding just the 1 afterwards...thank-you for your replies in advanceSmile...BlackPanther
