1. In file manager, why is it two root, A-root and B-root ??
2. How do i remove "profile directiory" in file manager ??
3. How do i remove the icon, leftside of the power-button on the main screen ??
4. How do i make xbmc start directly after i boot my htpc, i dont want to see the windows desktop ??
/Windows 7 and xbmc Eden beta 3
1. So you can transfer files from one directory to another easily.
2. You can't.
3. By editing the skin.
4. Probably just put it in the startup folder.
Ok, thanks.
Just needed to drag the xbmc-icon from the xbmc-folder under START, to Autostart-folder.
I added UPnP Devices as source but it cannot find the 1,8" harddrive.
The hdd got the G: as letter and when i unpluggs the hdd the G: source is still there.
When inserting a usb-stick, do i have to add the source everytime ??
In Videos, theres File and Playlists, is there any way to remove the Playlists from the screen ??
What am i suppose to do when insert a hdd or usb-stick ??
Any way to make it pop up as a usb or something ??
in XBMC v11 beta, USB drives auto mount under "Files"
16gb Sandisk Cruzer usb-stick does shows up auto under files, but not my Samsung S1 Mini 250gb 1,8" harddrive.
Whats wrong ??
Im using windows 7 and xbmc Eden Beta 3.
Silver Fang Wrote:16gb Sandisk Cruzer usb-stick does shows up auto under files, but not my Samsung S1 Mini 250gb 1,8" harddrive.
Whats wrong ??
XBMC auto mounts removable storage so you can get at it through the Files section. I suspect XBMC is treating the hard disk as a fixed disk, and you'll need to add a source for it.
JR
Oh i understand now, though it was a bug.
Tried my mp3-player and it showed up as a usb-stick.
Ok, thanks for the help.
