2012-02-27, 14:22
I am starting to see an issue where my video sources are loosing the content type setting. In other words, a source that was originally set for tv and set to use thetvdb as the scraper will for some reason suddently change to none. I am using a shared library setup with 2 XBMCLive boxes and the library on a Windows XP PC with mysql. I am assuming that this content setting is stored in the mysql database since when it is lost, is lost on both XBMCLive boxes. Also, this only started after I went from the mysql server running on a Linux PC to this Windows XP PC. It's actually the same PC, I just wiped out Linux (Mint LMDE) and switched back to Windows XP.
This really becomes a problem because I also have a script to run a library clean every night and if the content setting is gone, everything in that source is removed from the library. I'm not really sure where to even begin in looking for why this happening. My assumption is that it is a mysql issue but I can't think what would trigger it.
I'm still running 10.1 Dharma XBMC Live, and on the windows XP PC it has Msql Server 5.5. Also, if it makes any difference all of my video shares are on the same Windows XP box that the mysql server is on.
