(2012-03-15, 05:36)GeezerJT Wrote: [ -> ] (2012-03-04, 15:31)deanmv Wrote: [ -> ]GeezerJT Wrote:Where can i get the file? that looks great
Clipconverter.cc
Sorry i dont understand what i am supposed to do with that?
Type it into your browser :)
http://Clipconverter.cc
and then what am i supposed to do with it? i dont understand the instructions on the first post.
That link is a youtube "ripper:, it will grab the video file off the link that was in
http://forum.xbmc.org/showthread.php?tid...pid1036085 which you said you wanted to get.
Or if you have the video then what bit are you stuck at? The instructions seem pretty straight forward but where have you got to so far?
Just a quick side note is stuff like that allowed from a your stealing stuff of youtube/privacy point of view?
(2012-03-16, 00:27)deanmv Wrote: [ -> ]That link is a youtube "ripper:, it will grab the video file off the link that was in http://forum.xbmc.org/showthread.php?tid...pid1036085 which you said you wanted to get.
Thanks for the reply, i would be stuck at the veryfirst bit. Where do i find the Advancedsettings.xml ?
(2012-03-16, 00:51)GeezerJT Wrote: [ -> ] (2012-03-16, 00:27)deanmv Wrote: [ -> ]That link is a youtube "ripper:, it will grab the video file off the link that was in http://forum.xbmc.org/showthread.php?tid...pid1036085 which you said you wanted to get.
Depends on the system you are using. Also it might it might not exist yet as it is a user created file:
http://wiki.xbmc.org/index.php?title=Use...ttings.xml might be a good place to have a read for more info on it.
(2012-03-14, 20:19)ronie Wrote: [ -> ] (2012-03-14, 19:40)matt77303 Wrote: [ -> ]Thanks mate.
working ok now, could never get it to work before.
i can see the menu for about a second before it plays any way round that?
Matt
here's a minimal Startup.xml for Confluence that will delay the loading of the home screen by 1 second.
you can adjust the value (it's in milliseconds) of the delay to your own liking.
<window>
<onload>PlayMedia(special://skin/introMovie.mov)</onload>
<defaultcontrol always="true">10</defaultcontrol>
<allowoverlay>no</allowoverlay>
<controls>
<control type="button" id="10">
<onfocus>ReplaceWindow(Home)</onfocus>
<texturenofocus>-</texturenofocus>
<texturefocus>-</texturefocus>
<animation effect="fade" delay="1000" end="100">Focus</animation>
</control>
</controls>
</window>
so i just replace my startup.xml with thisw one?
Thanks again
Matt
(2012-03-17, 01:16)matt77303 Wrote: [ -> ]so i just replace my startup.xml with thisw one?
if you're using confluence, yes.
I am hoping that stoli will integrate this addon into neon and metropolis skin. Great work on this.
(2012-03-17, 01:48)ronie Wrote: [ -> ] (2012-03-17, 01:16)matt77303 Wrote: [ -> ]so i just replace my startup.xml with thisw one?
can a similar thing be done in home.xml? (using neon btw)
thanks
(2012-03-19, 14:53)rflores2323 Wrote: [ -> ]I am hoping that stoli will integrate this addon into neon and metropolis skin. Great work on this.
Already added to Neon. Will get it in Metropolis next.
Does anyone else have any cool intros??
(2012-03-25, 06:55)rflores2323 Wrote: [ -> ]Does anyone else have any cool intros??
I take you've looked at
Frost's addon posted earlier in this thread ?
Edit OK so I'm offcially still asleep. just seen your other post. Must be sleepbrowsing
Hi All,
I'm embarrassed I can't get this to work. The standard startup is disabled but I can't get the movie to play at all. Can anyone tell me what I'm doing wrong?
1) I added an intro movie here
/private/var/mobile/Library/Preferences/XBMC/userdata/Intro
2) Amended (confluence) startup.xml as below
<window>
<onload>PlayMedia(special://var/mobile/Library/Preferences/XBMC/userdata/Intro/IntroMovie.mov)</onload>
<controls>
</control>
</controls>
</window>
3) Disabled the startup splash using the script from here
http://forum.xbmc.org/showthread.php?tid=124124&page=6
(2012-03-26, 17:48)logan_x50 Wrote: [ -> ]Hi All,
<window>
^ there's you problem.
you can't just make up special:// paths :-)
try with <onload>PlayMedia(/var/mobile/Library/Preferences/XBMC/userdata/Intro/IntroMovie.mov)</onload>
or <onload>PlayMedia(/private/var/mobile/Library/Preferences/XBMC/userdata/Intro/IntroMovie.mov)</onload>
Ronnie, you beat me to it.
Btw, I finished working on an iPhone game titled Dummy Defense (shameless plug. Everyone check it out. I created the art and someone else handled the programming). Anyway I've got some free time and will be creating some more intro vids.
