2012-03-04, 09:43
2012-03-04, 14:13
I've updated the XML for VietnamTV.
1) It was malformed.
2) SCTV5 showed the stream of SCTV6, SCTV6 showed the stream of SCTV3
3) Added nicer transparent images to VTV and HTV
Find it here: http://tinyurl.com/vietnamtv-xml
(dtsexpert: Do you actually watch those streams? mikey1234: If you parse xml in some strange way, it's no wonder your plugin is slow.)
2012-03-04, 18:09
is LiveTv down for everyone today?
2012-03-04, 18:21
chetvitinh Wrote:is LiveTv down for everyone today?
Mine its working so far.. I have only watched few channels from Uk and US though, have not checked others yet!
2012-03-04, 18:26
As I know, The LiveTv list is not up-to-date as theStreamDB. If you like LiveTV, you can still use the plug-in with theStreamDB by setting it up as URL.
2012-03-04, 18:34
Mike1234 is not longer maintaining his links. For that, we must add Blackoutworm's url to be up to date.
2012-03-04, 18:47
No you dont just install v1.3
http://live-tv-stream.googlecode.com/fil...TVv1.3.zip
it is now pointing to Blackoutworms xml..........................you need to first click on add livetv as source then remove all old sources including streamdb as LiveTV is the same xml
2012-03-04, 18:56
Thanks Mike1234 for the clarification.
2012-03-04, 19:03
mikey1234 Wrote:No you dont just install v1.3
Hi how do we remove all theses files please
2012-03-04, 19:07
If you have LiveTV and have added streamdb as source simply right click on streamdb and remove
Obviously after you have added LiveTV as source first
2012-03-04, 19:08
XBMCOWNER.. once you have Livetv as main xml. Open Livetv again and it will give you the xmls you've had previously installed. Just click and hold until it says ** remove from....* click on it and voila!
2012-03-04, 19:11
thanks guys, I think last night when I update librtmp & default.py for rtmpGui to be able to play UK link without stopping or freeze after 60second, that might cause my script error for LiveTv and theStreamDb. I will play around some more
2012-03-04, 19:15
Macpatto Wrote:XBMCOWNER.. once you have Livetv as main xml. Open Livetv again and it will give you the xmls you've had previously installed. Just click and hold until it says ** remove from....* click on it and voila!
Thank you very much that worked
2012-03-04, 19:16
XBMCOWNER... Glad to hear that..
Enjoy it!!
Enjoy it!!
2012-03-04, 19:26
This is the best thing to have (LIVETV)
